Question about QuarkXPress v.9.0 - Complete Product - 1 User
I have been working on a Quark 9 file and all of a sudden I can't open it. I can't even drag it to the desktop. In the open recent menu item it displays ans volume not mounted.
Restarted Quark. opening from the desktop and through the application. Tried renaming but won't allow me to.
How can I add my own pdf files to the sd card
I have a couple of android tablets. To transfer files to the microSD card, I plug the USB cable into my laptop where the files are and make sure it is *connected as a media device* in Settings or the drop-down menu in the Kit Kat operating system. Then I use Windows File Manager to choose and copy files to the SD card. Windows File Manager displays the android device and shows the internal storage and the microSD card storage. Be sure to open the SD card storage by clicking on it and then create a folder called Downloads if there isn't one already there by that name and then copy your .pdf files into that folder. If you wish to create a sub-filed in the Downloads folder called PDF to keep things better organized you can do that as well.
Good luck.
Mar 08, 2015 | Tablets & eReaders
Tip
How to Transfer Files to Your iPhone or iPad For Newbies
<span> <p>A friend of mine recently called me, frustrated, because he couldn't figure out how to get PDFs on his iPad. While it's actually a very simple operation once you know how to do it, it's not something that's very obvious to people who are new to iOS (as many iPad users are). Here's a look at the simplest method of transferring files to an iDevice for those who don't yet know how to do it.<br /> <p>The video above will walk you through the process visually, but here are the basic steps you need to follow:<br /> <ol> <li>Connect your iPhone, iPod touch, or iPad to iTunes. (You can let it sync if you want, but this isn't necessary.)</li> <li>Click on your device in the list on the left side of iTunes. (It'll be under the "DEVICES" header.)</li> <li>Click the "Apps" tab up on top in the main panel of iTunes.</li> <li>Scroll down to the bottom where you'll find a "File Transfer" section with a list of apps. From that list, choose an app you want to transfer a file to.</li> <li>Onto the (probably empty) space to the right of the apps list, drag in the file you want to transfer. You can also click "Add..." to browse for the file and choose it. As soon as you've chosen the file, it will transfer to your device. You'll see the progress at the top of the iTunes window. When it's done you can disconnect and your file will be on your device.</li></ol> <p>Some apps provide additional ways to transfer files that you may prefer, but this is the most straightforward method and it works for every app that supports files. If you'd prefer to transfer over Wi-Fi (or another method), check the app to see if it has other methods. These methods vary from app to app, but most provide instructions so you can learn how to use the various transfer methods. They're worth exploring if you prefer to avoid connecting your device to your computer every time you want to transfer a file.<br /></span>
on May 31, 2011 | Apple iPad (16 GB) WiFi Tablet PC
How do I download music to this notebook pad?
The easiest way to download music is to drag and drop files from a PC to the table when you link the tablet as an external drive. If you want to wireless transfer files then you can use an app such as Cheetah Sync. Direct download from online sites such as Amazon or Google Music allow one-click download options after purchase.
Mar 06, 2015 | Tagital Tm 9" Android 4.0 Tablet PC...
How do i download this file from my laptop to my maxtouuch
Well, if it's a Windows PC it will be in "Computer" and has a drive letter assign to it and you can drag or send files to it. On the Mac it just shows up on your desktop and you can just drag files to it. If there is a specific backup program you are trying to use, please tell us the make and model of both the laptop and hard drive and the Operating system of your computer.
Nov 19, 2013 | Tablets & eReaders
Forgot password
Go to Barnes & Noble's website on your computer and select the option to create an account. Enter your full name, email address, debit or credit card information and select a user name and password when prompted.
If you have a Barnes & Noble account, skip this step.
Power on the Pandigital Novel and tap "Settings" on the home screen.
Tap "General, and select the "B&N Account" and "Password" fields and enter your Barnes & Noble account login information.
Reading ebooks is not the only activity you can enjoy with the Pandigital Novel.
The multi-functional device will also allow you to listen to music, watch videos and browse through your favorite images.
The Pandigital has a speaker located in the back of the device and an earphone jack to accommodate your listening needs.
To get started, you will need to either download media from a computer or purchase ebooks from Barnes & Noble online.
Downloading Media
Connect the Pandigital Novel's USB cable into the compatible mini USB port on the right side of the device. Plug the other end of the USB cable into the computer's USB port.
Click on the computer's desktop "Start" menu.
Choose the "My Computer" or "Computer" folder in the desktop Start menu.
Double-click to open the "PD_Novel" drive in the My Computer/Computer folder.
Inside the drive there are four separate folders "eBooks," "Photos," "Music" and "Videos."
Drag compatible media files stored on the computer to the compatible folder inside the "PD_Novel" drive with your mouse.
For example, drag audio files to the "Music" folder.
The Pandigital is compatible with text formatted as ePub and PDF, audio files formatted as MP3, AAC, WAV and OGG, video files formatted as MPEG-4 and images formatted as JPEG, BMP, PNG and GIF.
Disconnect the Pandigital Novel from the USB cable.
Playing Media
Press and hold the "Power" button, located on the left side of the device until the boot up message appears on the screen.
Select a media option in the "Application Quick Launch Bar" at the bottom of the screen: Reader, Music, Videos or Photos.
Tap the desired song, video or image and tap "Play" or "View."
Tap the "Pause/Play" and "Previous/Next" options to control the file or go to the next listed file.
Setting Up Wi-Fi
Turn the "Wi-Fi" button, located on the top of the device, to the "On" position.
The Pandigital Novel will automatically scan for local Wi-Fi Networks.
Tap the desired network from the list of found networks.
Enter the network password, if prompted. Then tap "Connect." When connected, tap "Next" to continue.
Purchashing eBooks
Tap to go back to the home screen.
Select "Bookstore" from the home screen.
The Barnes & Noble bookstore will open in the Pandigital Novel screen.
Search the website for ebooks to purchase.
Tap on the book cover and select either "Buy Now" or "Get Free Sample."
Tap "Yes" to download the media cover to "My Library" when prompted.
Go back to "My Library" on the home screen and tap on the media cover.
Confirm to download the ebook to your Pandigital when prompted.
The entire media file will download.
http://www.pandigital.net/userfiles/file/Downloads/UG_PRD07T-1_v3.4_09-10-10.pdf
Barnes & Nobel
http://www.bn.com/
Aug 10, 2013 | PANDIGITAL Tablets & eReaders
I downloaded Skype on my 4Sight 9" Android 4.0 tablet but it won't open. How can I fix it?
I've had trouble with downloaded apps not working and everytime I did I would delete the app, turn my device off then back on, and then reinstall the app.
Dec 13, 2012 | Tablets & eReaders
I can't open .jar/.jad files in my tab GT P1000
Jad & .Jar are usually associated with games/application files To open a .Jad you could use notepad to see what it contains.. the file itself acts like an address page for the .Jad to unload into the correct places withing a Java program .
JAR (Java Archive) and JAD (Joint Application Development) files are packaged
files containing games and applications that can be unpacked onto your cell
phone with the use of a personal computer. Unlike similar files used by
smart phones, JARs and JADs are used on older and cheaper phones since the file
size is always small and can be easily extracted in order to load a game or
application.
  1. Attach the Tab/phone to your computer with its USB cable.
  2. Click and drag the JAR or JAD files to the root (starting) directory of your Tab/phone. On some phones, you need to instead move these to a games or apps folder.
  3. unplug the USB cable from the phone and the computer.
  4. navigate to the "Applications" or "Games" directory on the phone, where you will see the JAR or JAD file.
  5. Select the option to run or install the file. The application will be on your Tab/phone and ready for use..
Hope this helps!..if more help requires pls let me know.Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the
Community :)....Thanks
Jun 27, 2011 | Samsung Galaxy Tab Tablet PC
How do I install my Win XP whn I have changed my harddisk ?
plz follow the steps...
1. Insert windows xp bootable cd into the drive
2. Power on the machine
3. When the logo displays, press F12 to show the boot menu
4. Select the CD/DVD
5. System will start the job
6. After showing Setup is starting windows, it'll shows the install option
7. Press ENTER
8. It'll show the drive but the drive is not partitioned
9. You can easily understand by reading the instructions
10. While creating it'll ask for drive space
11. Put 50000
12. Press ENTER
13. It'll ask for type of file system that you have needed, select the 1st one (Quick using NTFS)
14. It'll ask 4 format the specific drive. for that you have to press 'F'
15. It'll format and copy the needed files
16. System will restart. After restarting it'll start the job. plz wait.....!!! (system restart many times to complete its job)
17. While working it'll ask for the product key, time, etc.
18. Sit infront relax and give the needed information that you can understand easily
thanks & regards
Anas K A
May 28, 2011 | Fujitsu Lifebook T1010 Tablet PC
I have a nook app on desktop on my laptop; was given an archos 101, I connected the USB cable to laptop & archos, dragged nook app to USB, but nothing show on the android
first you will need to go to Settings > applications > and then checkmark unknown sources. Then you will have to go to your file manager (like astro) and click on the .apk. The android installer will run and install the app.
Feb 17, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
QuarkXPress v.9.0 - Complete Product - 1 User Logo
Top Quark Tablets & eReaders Experts
Are you a Quark Tablet and eReader Expert? Answer questions, earn points and help others
