Question about Hitachi Heating & Cooling
Where can i get a PC Board for a Hitachi RAS-25CHA airconditioner
Electrician said this part not available
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
When I start the AC the power switch trips
change your mcb and checked your voltage and compressor
May 11, 2009 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS 5142CHA Won't operate
Check the fuse on the control board inside the head unit,if its ok you need to replace the contrl board
Apr 04, 2009 | Hitachi RAS-09UH Air Conditioner
Air conditioner stopped working
Check the breaker in the panel and the fuses in the disconnect at the outside unit. If that doesn't do it. call a heating and air technician instead of an electrician.
Mar 01, 2009 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS-25CHA will not work after power supply -brown outage.
Is the unit responding to remote instruction at all? It does sound like your board is gone. This is usually a capacitor (blue or green and round flat disc) on the pc board, and possibly one of the diodes (small black cylindrical shape with a white line on one side) Often it is the compressor drive relay (rectangular black box) on pc board. If however you have managed to find a replacement board. The plastic heads holding the pc board are released by using a small long nose pliers and pinching the bit sticking through the board. The rest is simply a matter of changing one wire at a time from old board to new board. Or a good method is just to take a snapshot with a camera to refer to regarding the wire positions.
Jan 30, 2009 | Heating & Cooling
Heya,
I am an ex warrenty agent for Hitachi in Western Australia and I will be able to take you through some tests if you want. But from the sounds of it I think that you will be up for a new indoor PCB as these are the most common things to go when there are power failures. If you would like me to go through it with you let me know. But first where abouts are you in Australia?
Jan 08, 2009 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS-63CHA2 split system reverse cycle air con
You can try universalremote.com but it cost me 15USD for digital delivery. Its better than being cold and I have spent hours on the net to no avail.
May 22, 2008 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
