Question about Radio Communications
My plantronics ml20 can't detected on my cellphone
How do you turn the PLantronics 520 off when not being used without losing the pairing
Press and hold the main button for three seconds to turn off the headset. Turning off the headset will not cause you to lose pairing with your cellphone. You can find more information here.
Mar 04, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Toshiba laptop with IOgear bluetooth adapter installed will recognize phone but won't detect plantronics explorer headpiece. I would like to use it to chat on skype
If the Bluetooth adapter can detect the phone but not the Plantronics headpiece, then there's no problem with your computer or your Bluetooth adapter. The problem has something to do with the Plantronics.
Try to turn the headpiece off, then turn it back on. Set it to discovery mode, then try to detect it using your computer. If that did not help.
Try to detect the Plantronics, using your phone. That will help you in isolating the problem.
Aside from that, make sure that no possible wireless interference while you're searching for the headpiece. Cell phone, base of the cordless phone should be away from the computer while you're searching for the headpiece. Because Bluetooth and cellphones/cordless phones are running on the same 2.4GHz frequency RF signal. They might interfere with each other.
Apr 14, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I can't pair up my plantronics Explorer 390 to my LG Xenon cellphone
For most Plantronics products, this passkey is 0000
please Rate me +++++
Jan 05, 2010 | Plantronics Explorer 390 Bluetooth Headset
Cant pair it with my cellphone
Turn your phone's bluetooth on. Press and hold the call button on the headset until the phone detects it. When prompted for a password enter 0000.
Sep 21, 2009 | Plantronics Hama Voyager 520 Bluetooth...
Passkey for plantronics 233
Standard password for syncing is 0000 on your cellphone.
Apr 28, 2009 | Plantronics Explorer 220 Bluetooth Headset...
My new phone can't even detect this plantronics
The sciphones have a VERY SHORT area to use bluetooth devices. I have contacted numerous companies about this. Mine works, but I need to have my sciphone on my shoulder while I am using the bluetooth headset. This sucks, but so far that is the only way I have gotten mine to work properly. Hope this info helps a little.
Apr 23, 2009 | Plantronics Explorer 220 Bluetooth Headset...
No Program folder for Plantronics application / driver.
The CS50-USB from Plantronics extends wireless freedom to your softphone. It’s the first wireless headset for VoIP applications with remote call detection and answer/end capability via PerSonoCall software (built-in).
Enjoy yourself without bothering about software!
Jan 05, 2009 | Plantronics CS50-USB Professional Headset
Music
The Plantronics Explorer 330 doesn't have the A2DP technology (Advanced Audio Distribution Profile) for streaming music, you need to look for a headset that has the A2DP Bluetooth profile built in like the new Plantronics M50. The Plantronics M50 is a new model which is now available and is in the $47 range.
Below is a link to the M50.
Plantronics M50
Good luck from Headsets Direct!
Oct 06, 2008 | Plantronics Explorer 330 Headset
Connect Plantronics Explorer 330 to Verizon Moto W755 Cellphone
See page 6 of the Explorer 330 user guide for the correct pairing instructions. Link included below.
Plantronics Explorer 330 User's Guide
Good luck from Headsets DIrect!
Aug 01, 2008 | Plantronics Explorer 330 Headset
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
