Question about Gates 2002 Mazda Protege Timing Belt 02 Mazda Protege
Set timing on 02 Mazda protege - Gates 2002 Mazda Protege Timing Belt 02 Mazda Protege
Window wont go up
Power window repair - Mazdas247
www.mazdas247.com > ... > Mazda Protege Forum > Protege How-To
Aug 8, 2005 - 10 posts - ‎10 authors
I have a 2002 and last week the driver's side power window died a horrible death. ... Check out my mods -> 2001 Mazda Protege LX aka Rum Runner ... My front pass sidewindow won't go up or down anymore. haven't taken ...
Passenger Window on 2007 CX-7 will not come up ...
Nov 28, 2012
Driver's side window auto-up/down issues - Mazdas247
Jun 10, 2011
Power Window Problem - Mazdas247
Aug 9, 2009
Driver Side window controller won't work
Nov 11, 2006
More results from www.mazdas247.com
2003 Mazda Protege 5 Replacing The Power Window Motor ...
? 7:02
https://www.youtube.com/watch?v=N3GP2UwTtAQ
Feb 3, 2015 - Uploaded by Steve K.
2003 Mazda Protege 5 Replacing The Power Window Motor and Regulator. Steve K. ... Looks like you just ...
Amazon.com: Dorman 741-741 Mazda Protege Fr
Oct 30, 2015 | 2002 Mazda Protege
Correct way to install g timingbelt 02 Mazda protege
You get instruction book with the new belt
You look at your factory service manual before you
start any job
You could try the internet or you tube video
Dec 08, 2014 | 2002 Mazda Protege
Install timing belt correctly on 02 Mazda protege
The instructions to do that are beyond the scope of this site. Recommend that you buy a manual that describes how to do the job. It's not somethign you should do if you lack the experience.
How do you set the timing
On what engine usually anything with a timing chain the 2 gears have indents that should be pointing straight at eachother
Mar 15, 2014 | COMP Cams Hi-Tech Roller Race Timing Set:...
Mazda protege will not engage manual transmission
Check clutch, throwout bearing, clutch pressure. linkage may be binding or broken between shifter and tranny. Make sure you have the right type of clutch installed.
Feb 08, 2014 | TRANSMISSION Mazda Protege 1999 99 2000 00...
02 mazada protege code P0660
P0660 Intake Manifold Tuning Valve Control Circuit/Open.. Although you may want to first look at a new EGR Valve - particularly in Mazda.
PS: Your local auto parts store can also define OBD II Codes.
Best regards
Ck
Sep 24, 2011 | 2001 Mazda Protege
02 mazda protege doesnt have any power and it has a knock to it like it missing firing
Well thenRemove 1 plug lead at a time and when the missing stays the same and dosent miss on 2 then you have the correct cylinder OR it could only be the plug faulty or lead ,but if none makes any differance then the knocking will be something else like Tappet lack of oil ,, valve hiting a piston, or timing moved.
Try all of the above and let me know how you get on . Ron
Oct 11, 2009 | 2000 Mazda Protege
WHEN DO YOU CHANGE THE TIMING BELT IN A 2002 MAZDA PROTEGE.?
I have an 02 Protege5 which is pretty much the same engine. I changed mine at 105000 km's. Generally, you do it at about the 100000 km (62000 mile) mark. However, I know of others who pushed their cars to 150000 kms. Good news is that I believe that the Protege uses a non-interference engine (means the valves wont crash into the pistons if the timing belt breaks). However, you should double check this with your local Mazda dealership. Dont take my opinion for word.
Apr 22, 2009 | Protege Computers & Internet
97 mazda protege 1.5L
how do you know timing is off w/out a timing light
Oct 01, 2008 | 1997 Mazda Protege
Mazda protege antitheft system
2001 protage the battery keeps dying. What could be the problem.
Sep 11, 2008 | 2002 Mazda Protege
Gates 2002 Mazda Protege Timing Belt 02 Mazda Protege Logo
454 people viewed this question
Top Gates Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Gates Hardware and Accessory Expert? Answer questions, earn points and help others
