Question about Gates 2002 Mazda Protege Timing Belt 02 Mazda Protege
Replace timing belt 02 Mazda protege - Gates 2002 Mazda Protege Timing Belt 02 Mazda Protege
2 Suggested Answers
mhunsberger5
  • 16 Answers
SOURCE: how to find timing when installing timing belt to
Personally, I use a paint stick to mark the original belt location. Then I take the belt off and transfer the marks to the new belt. Be sure to put a new water pump in and also a new spring on the tensioner.
If you already took the beloff, then there are actually timing marks. I forget where the mark on the crank is, but it should be slightly obvious. The mark on the gear lines up with a mark on the oil pump. The camshaft gears each have 2 marks. On the front you use the one with the 'e' and the 'I' on the back. The notches have to point at eachother parallel to the cylinder head.
Good luck...
Posted on Nov 13, 2014
Install timing belt correctly on 02 Mazda protege
The instructions to do that are beyond the scope of this site. Recommend that you buy a manual that describes how to do the job. It's not somethign you should do if you lack the experience.
Dec 08, 2014 | 2002 Mazda Protege
Alternator belt replace
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Jan 26, 2012 | 2000 Mazda Protege
How to replace a timing belt on a 2000 Mazda Protege
Here is a website that a free manual can be down loaded for your vehicle
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 01, 2010 | 2000 Mazda Protege
How do you replace the water pump on a 1992 Mazda Protege?
Hi:
The water pump is driven by the timing belt, which is on the passenger side of your engine. You would need to remvoe all belts, and then the timing belt cover, and the timing belt to change your water pump.
Dec 02, 2009 | 1992 Mazda Protege
Need diagram for timing belt for 1991 mazda
here you go buddy
http://forums.mazdaworld.org/index.php?showtopic=25269
http://www.2carpros.com/forum/1994-mazda-protege-replacing-a-blown-head-gasket-vt206242.html
http://www.2carpros.com/forum/2000-mazda-protege--my-timing-belt-broke-again,-oil-pressure-vt253721.html
http://www.blurtit.com/q298393.html
hope this helps.
thanks,
voodoo
Aug 09, 2009 | 1991 Mazda Protege
WHEN DO YOU CHANGE THE TIMING BELT IN A 2002 MAZDA PROTEGE.?
I have an 02 Protege5 which is pretty much the same engine. I changed mine at 105000 km's. Generally, you do it at about the 100000 km (62000 mile) mark. However, I know of others who pushed their cars to 150000 kms. Good news is that I believe that the Protege uses a non-interference engine (means the valves wont crash into the pistons if the timing belt breaks). However, you should double check this with your local Mazda dealership. Dont take my opinion for word.
Apr 22, 2009 | Protege Computers & Internet
Timing Belt on 2002 Mazda Protege
every 90,000 to 100,000miles and yes it is strongly recomended to replace the water pump with it
Apr 02, 2009 | 2002 Mazda Protege
How much should I reasonably pay to replace the Timing belt in my 2002 Mazda Protege 5?
replacement of timing belt $350-$500. aftermarket shops will try to sell you a package containg a belt, water pump, and tensioner pulley. the dealer will just replace the belt, they might recommend to replace the water pump if there are alot of miles on the car, they will also inspect the pulley for wear.
Jan 01, 2009 | 2002 Mazda Protege
Gates 2002 Mazda Protege Timing Belt 02 Mazda Protege Logo
454 people viewed this question
Top Gates Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Gates Hardware and Accessory Expert? Answer questions, earn points and help others
