Question about DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker
Does anyone have a repair manual for a DeLonghi PrimaDonna Avant ESAM6700 coffee machine? If so, could I have a copy?
  • Harry LePage
    Harry LePage Dec 10, 2014
    Thanks for replying. Unfortunately, DeLonghi only have the User Manuals on their website, which give no information on how to disassemble the machine. So, if anyone can point me in the direction of a repair/service manual, I would really appreciate it.
  • 512 Answers
SOURCE: Instruction Manual
Go to http://www.delonghi.com then go to customer service. They will get for you.
Posted on Jun 17, 2009
SOURCE: milk container won't fit onto front of machine
We had the same problem & worked out that it's because the actual milk container is too cold & has contracted from being in a cold part of the fridge. We moved the milk container to the door of the fridge ( it's a little warmer than the rest of the fridge) & it slotted in perfectly the next morning!
Posted on Aug 17, 2009
mcdevito75
  • 1970 Answers
SOURCE: i need a manual for my delonghi cafe parma machine
mcdevito75 here, You may be able to get the manual online at Delonghi Caffe espresso machine.
Posted on Jun 20, 2010
trick1_rm
  • 285 Answers
SOURCE: My delonghi esam6700 prima donna avant displays fill tank every time in turn it on, I fill the tank up and insert and it keep displaying the same message fill tank, everything I've tried won't work do
Maybe if you unplug it it will reset when plugged back in or if there is a float that is stuck down.
Posted on Aug 12, 2014
edwardh21370
  • 78 Answers
SOURCE: Our PrimaDonna coffee machine doesnt
From the question I understand that the steam jet is rushing into the cup but it is not able to draw milk. The jet of steam sucks the milk from the container (within a reasonable distance from the frother). With proper air mix from the air inlet in the frother, it generates foam. Suction of milk is enough when the milk tube connection at the frother end is airtight. Air sucked into the frother with milk (due to loose connection) reduces the suction of milk. Please try the following:
1- Make sure the connection of the frother to the steam outlet is airtight. Air sucked in at this connection also reduces the suction of milk from the milk container.
2- Make sure the tube drawing milk from milk container to the frother is airtight.
An extra suggestion to a related matter: Many operators feel that the steamed milk is not hot. This happens when the flow of milk id more than the steam can heat. Reduce the flow of milk for hotter foamed milk.
First slightly pinch the tube between finger and thumb to reduce milk flow. If that results in a better temperature of milk filling the cup, then you need to find a flow constrictor device.
The flow constrictor is a simple bushing with a hole through it to allow milk tube to pass through. There a screw (metal or plastic) threaded through its wall that can be tightened to pinch the milk tube and reduce the milk flow .
Please check the following link for the flow reducing device:
Services Unlimited Inc Parts Guru
Good luck. Please post the result if the above worked.
Posted on Oct 20, 2014
Where on the delonghi Prima Donna s delux coffee machine is the "coffee bean empty" sensor
look in the bin hopper for a clear panel and wipe it off good I hear they get dusty
Nov 20, 2015 | DeLonghi PrimaDonna S Deluxe Super...
My primadonna has started to make very loud noises when preparing coffe and also when it returns aften the coffee has run through! Like a squeeking noise and very loud. Anyone who knobs What to do? The...
Possible cause is the vertical 'screw' shaft that the brew unit moves up & down on. Best have it checked out by a repair shop as there is little you can do unless you have had one of these apart before - not recommended.
Feb 07, 2015 | DeLonghi Prima Donna Avante ESAM6700...
Delonghi problems
turn off the machine and after 2 minutes turn it back on
Sep 01, 2014 | DeLonghi Prima Donna Avante ESAM6700...
Ma I know how much of this machine?
call 07779933829 if you need help repairing this unit
Jan 18, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Recently descaled delonghi prima donna not frothing
milk unit pipe s blocked needs strip down...07779933829 uk we repaire
Jan 15, 2011 | DeLonghi Prima Donna Avante ESAM6700...
DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker Logo
195 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
