Question about Grohe 32.073.KD0 K4 Prep Sink Dual-Spray Pull-Out Kitchen Faucet - Stainles
How to install a new Grohe pull-out spray hose
4 Suggested Answers
  • 74 Answers
SOURCE: Grohe 32 071 K4 spewing water from single vale or tube under sink
There should be an o-ring on the mating surfaces of the hose and the faucet that my be missing.  It could also me that the big washer in side of the faucet (under the cartridge) has been shifted.
I doubt it is the cartridge itself, always try the cheap ideas first.
Posted on Apr 14, 2009
  • 50 Answers
SOURCE: grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
Posted on Jun 11, 2009
  • 52 Answers
SOURCE: replace button on pull-out sprayer
With your faucet in the off position pull the sprayer out. Unscrew the hose that connects to the sprayer. This lets you take the sprayer to someplace where you can sit down. The front of the sprayer where the water comes out unscrews as well. You may need to use a nonslip mat or a piece of rubber but you can undo this by hand. Once you have this off a small piece (airator) can come out that helps control water flow into a steady stream instead of the way water comes out of a garden hose with no nozzle. form here you'll be able to see how the old button fits into the sprayer, pop it out and replace with the new one. Assemble in reverse.
Posted on Feb 16, 2010
Grohe 46 092 000 Pull-Out Spray Replacement Hose, StarLight Chrome I have the part are there any videos that show how to replace it
How to Replace a Kitchen Sink Spray Hose - YouTube
? 1:43
www.youtube.com/watch?v=oIt4ofmCEAk
Oct 4, 2012 - Uploaded by About.com Learn how to safely and correctly replace a kitchen sink sprayhose. ... How to Connect a Sink Sprayer : Home Sweet Home Repair - Duration: ...
Sep 27, 2015 | Grohe Home
Need to replace rubber on Grohe Ladylux Plus Pull out spray handle. How to get spray handle apart.
I bought DANCO "universal faucet pull-out spray hose - fits all facuet brands" from Lowe's, which came with all kind of adapter and the hose quality seems to be better than overpriced Grohe spray hose replacement (Grohe part # 46092). The only problem is that you may have to prepare a large rubber washer in order to the handspray (Grohe part#46298) as I don't see this large washer in the package but it is very important to fit in place to prevent water leakage. - Michael
Jan 13, 2012 | Plumbing
Grohe ladylux cafe kitchen faucet: new item, the pull out spray piece does not set firmly into neck so that it falls out easily
check and see if the weight is on the hose going to the handle, also check to see if the hose is free to fall down and that it is not hanging up on piping down under the sink
Best of Luck
Richard
Sep 06, 2011 | Grohe Plumbing
I'm trying to replace the flexible hose on my Ladylux Plus but the hose doesn't seem to pull through.
If you remove it from the sprayer and then pull it out the bottom it should come out quite easy and you will also need to remove the weight and add it to the new hose after the new one is installed.
Aug 22, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe ladylux plus kitchen faucet leaks from multiple points along metal pull out hose attached to faucet head. Is this fixed by replacement of same hose? How do I replace the hose?
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Feb 23, 2010 | Grohe Plumbing
Grohe pull out kitchen faucet the inner tube ripped
Jun 11, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
My grohe kitchen faucet hose won't retract
the first thing you need to check is the weight on the hose under your sink. if it is set too high or to low it doesnt allow the proper weight to pull the hose back into position. also check to see if the hose is twisted under your sink also. I hope these answers will help you out.
Apr 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Mar 28, 2009 | Grohe 32.071.KD0 K4 Main Sink Dual-Spray...
Grohe 32.073.KD0 K4 Prep Sink Dual-Spray Pull-Out Kitchen Faucet - Stainles Logo
101 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
