Manual for blyss electric convector heater
Can you give me instructions as l have lost manual for blyss electric convector heater with timer it keeps cutting off and l don't know how to turn timer off and just use manually
  • 4 Answers
SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Nov 16, 2007
treloss
  • 9 Answers
SOURCE: manual for ultrak 340 sports timer
Here is a link to pdf maual file. This should help.
www.cei-ultrak.com/sport-stopwatch/pdf/340.pdf
Posted on Oct 28, 2008
SOURCE: keeps shutting off
I have a LASKO 5565 model fan and had a similiar problem. Cleaned the whole unit, thinking it was tripping the safety breakers, and it still would turn on and off. The control console was completely unusable. So then I thought that it was maybe the squat switch located on the bottom of the unit. I quickly deduced that not to be the problem and continued following the wiring. Just above the fan there is a 1/2"X1/2" thermostat. Upon touching it I almost burned myself. For some reason the unit was grounding here and cause the thermostat to heat up and shut the unit off. I took the thermostat out of the equation and the unit works great.
CAUTION: If you pursue this action you must understand that you no longer have a thermostat and the unit is now simply just a heater. It will either be on at full blast heat or it will be off. Good luck.
Posted on Nov 20, 2008
techniwiz
  • 275 Answers
SOURCE: Manual for Timex Marathon 50 lap memory timer
http://www.timex.ca/en/html/watch_instructions.html
Posted on Dec 04, 2008
tinytrees
  • 92 Answers
SOURCE: Instruction manual for hz705 honeywell oil heater
May I suggest contacting the manufacturer, Honeywell/Kaz direct at 800-332-1110.
Posted on Jan 23, 2009
Can not find the instruction manual for my III Woods #50016 outdoor timer. I do not know if it is similar to any of the other Woods timers that you've already answered questions for.
Here is the manual Janet
[PDF]Timer Instructions in English https://www.muni.org/Departments/health/.../timer%20instructions2012%206.pdf
  1. Cached
  2. Similar
Woods 50016 digital timer for use with engine block heaters. Refer also to enclosed directions for additional safety cautions and Spanish and French translations. Set timer to supply electricity to your vehicle's engine block heater 2 to 3 hours ...
[PDF]Woods 50016 timer manual - Water Heater Timer
waterheatertimer.org/pdf/Woods-50016_Instruction-manual.pdf
  1. Cached
  2. Similar
Page 1. http://waterheatertimer.org/Woods-timers-and-manuals.html#50016.
Woods 50016 Digital Timer for Engine Block Heater: Amazon.ca ...
https://www.amazon.ca/Woods-50016-Digital-Engine-Heater/dp/B006LYHG4W
  1. Cached
Rating: 2.2 - ‎8 reviews Set timer to supply electricity to your vehicle, s engine block heater 2 to 3 hours before ... Woods 50016 Outdoor Digital Block Heater Timer, 24-Hour. ... rating: 15A, 1875-Watt; tungsten rating: 10A, 1250-Watt 8A ballast; controls up to 1/2 HP. .... This causes it to go into a setup phase and not provide power to my block heater.
Nov 15, 2016 | Woods Hardware & Accessories
Bylss 34hfu600grt electric fire. Where can I get instructions?
[PDF]LDBL2000A-DD5R EN - Free Instruction Manuals
www.free-instruction-manuals.com/pdf/pa_843360.pdf
CAUTION - Fire, electric shock, physical injury and material damage hazards: To use the appliance, always follow the instructions for and assembly, use ...
BLYSS 34HFU600GRT KURZ User's guide, Instructions ...
www.manualspoint.com/results.php?...BLYSS%2034HFU600GRT%20K...
User's guide, Instructions manual & Installation guide - Immediate download or search mode services.
Jan 07, 2016 | Home
I require an instruction manual for Blyss 300W Convector Heater with Turbo Fan & Timer - EAN 5052931077953
Try looking on the internet. I do not expect you will find a solution in the dehumidifier section.
Apr 01, 2014 | Dehumidifiers
Hi i have a rinni convector 516tr heater i put it on it switches off a few seconds later i think it has to do with the timers i have lost the book/
I am assuming this is a tankless heater. Are you turning the water on full throttle and is there full flow. First thing to check is the small filter screen on the inlet of the water heater. If the flow is reduced the water heat will not fire.
Sep 05, 2010 | Rinnai Heating & Cooling
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Rinnai Convector 404
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
235 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
