Question about Calvin Klein Euphoria
Tracking No. JL494247580GB I cant seem to track it
I have put the tracking no. JL494247580GB in and it says it doesn't exist
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
You might want to contact the company you placed an order with.
Posted on Aug 02, 2015
Why cant I track my parcel from texas U.S.A. ?
Some shippers have terrible or almost non-existant tracking on some deliveries. It happens everywhere else, too.
Sep 05, 2014 | Cars & Trucks
When I put a tape in, the screen says "auto tracking" and picture jitters all over the place. Manually pushing track up and down buttons on remote doesn't seem to have any effect. (Zenith...
You may have bad video heads casuing the unit to constantly trying to "auto track" to correct picture issues. You can try and run a head cleaner and see what that does, otherwise it sounds like time to replace the VCR. I hope this helps : )
Jul 25, 2011 | Televison & Video
My Cortex Dmix 300 has automatically turned autocue on so everytime I load a track on to play it immediately cues up at the first point of sound. Any attempts to re-cue the track just takes it back to the...
hmm there must be a button w a secondary function for the auto cue. if not are you using software with it. check there as well. if you cant find it let me know ill do some research for ya.
May 11, 2011 | CORTEX DMIX-300 Mixing Deck For iPod, MP3...
My jvc has developed a tracking problem when viewing tapes recorded on other recorders. I cant seem to correct the problem. It shows old tapes without a problem
VCR tracking has to be set up right, but even then many machines have problems with tracking other vcr's tapes. Generally a good quality commercial tape should track well. If it doesn't then either there's a fault with the tracking on your machine or the tracking is not set up right. Most tracking problems are caused by dirt, or wear on the heads or surfaces. Give your VCR a good clean up, every surface the tape comes into contact with, using Servisol Video 40. If that doesn't solve it you might have to look into the cost of replacing heads, maybe the control/audio head first. Or you should look at having the tracking set up by a proffessional (at a JVC service center). However if the tracking was off, after resetting any tapes the machine has done, may now have problems tracking, whilst other machines tapes and commercial will track normal.
Jun 28, 2010 | JVC HR-S6970 S-VHS VCR
Pads 5,6,7 & 8 don't work. Others plus memory are ok therefore using memories to make up some times.
Managed to fix problem after removing keypad/display. Problem was a break in one of the tracks on the flexicircuit connecting the pad to the PCB. Where curved over a free end of the flexicircuit substrate I could see a dark line across the track - a meter showed that the circuit was broken. Problem solved by careful application of silver conductive paint. Also cut back the substrate so no longer coincident with the damaged area and put across the free end some tape to provide additional protection for the future.
Would like to replace the keypad as use has caused plastic surface to start to break down but apparently no spares are available in the UK for this machine. Had to dismantle and repair the door interlocks a couple of years back for the same reason. Would buy a new machine but cant find one to match this one. Size and spec doesn't seem to exist anymore.
Dec 28, 2009 | Zanussi Microwave Ovens
Hi we just bought a used truck with a kenwood KDC-MP4028 cd player. After unplugging the battery we cant seem to unlock the security code.... Im going crazy with out my music, Help!
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
push buttom "track up" for 3 seconds
The security is canceled and the set enters the TUNER mode!
Oct 18, 2009 | Kenwood KDC-MP4028 CD Player
Excavator track needs to be put back on
after the idler is pushed all the way back into the frame.try to put some wood blocks under the track to remove all the slack.use the bucket to push as much of the bottom section under the bottom rollers.use a heavy chain and pull up and over the top of the roller.when you get close you can use the drive to walk it the rest of the way.if it still doesnt go you may have to break the track at the master pin. this is usually marked with a small hole drilled in the end of the pin.heat and beat the pin out,break the track.pull track over top rollers and make ends meet on top of the srocket.use a chainfall to pull two halfs together and line them up.drive pin back in and your all set.
Mar 01, 2009 | Gladiator Gear Track Pack
GENERAL QUESTION
I believe what Tascam means by the 'effect loop' on the 2488Mk2 is simply a send loop within the device which internal effects can be set on (vs. a the 'send loop' which exists when you send a track out the sends, through an external effect device, and then back through one the the 2488 inputs). This effect loop is sent to the stereo bus as well as the bounce sub mix.
To use the internal effects in this way you'd select a track with the 'select' button for the track (or you can do multiple tracks by repeating this process for each track one at a time). Then press the send button and on the top of the screen you'll see the effects loop. Just set your send there to 100 or so and that track will be sent to the internal effect loop and be affected by whatever single effects you have turned on. To print these tracks with effects you can either premaster or create a bounce mix. Just make sure you mute any tracks you don't want in a bounce because a bounce will record anything which is on the stereo bus.
(See page 42 in your manual for Tascam's explanation for using the single effect and page 58 for how to create a bounce submix).
Hope this helps.
bd.
Jan 26, 2009 | Tascam 2488 Portastudio Multitrack...
When i transfer music from my library it deletes all existing tracks from device
Are the existing tracks still on your computer? Most mp3 devices won't keep existing music on the device unless told to do so. Basically, don't delete any playlists or tracks from the program that you are using to transfer the music.
Jun 30, 2008 | Audio Players & Recorders
MP3 Samsung SGH-X830 mobile phone
type in *2767*6263# then let ur 4n start up again . this should fix it.
Jul 31, 2007 | Samsung SGH-X830 Cellular Phone
Calvin Klein Euphoria Logo
1,164 people viewed this question
Top Calvin Klein Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Calvin Klein Health and Beauty Expert? Answer questions, earn points and help others
