Question about Samsung RS2530BWP (25 cu ft) Side by Side Refrigerator
What part Samsung RS2530BWP uses, Sensor or Bar
My freezer side is not defrosting and trying to narrow down the problem. 2) Opened the panel, removed Defrost Thermostat and placed in ice and checked the for continuity. my Volt meter started to change numbers and stopped at 0.3 and sometime 0.2. Please advise if this means faulty part. 2) I see two parts on this website which i am confused about as to which one samsung RS2530BWP uses and how to test if the one i have is faulty. a) Samsung Refrig Temperature Bar DA32-00029A b) Samsung Refrig Sensor DA32-00006W Thanks in advance.
  • Anonymous Dec 10, 2014
    Hi Fazal Iqbal, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    also check the fan is rotating in the freezer {at the back behind the panel } if the fan cant rotate then the element will overheat and fail the thermal fuse
    i think as the fan failed the heating element {anti frost system} has blown its inline thermal fuse because the fan isnt there to blow the heat from the compartment the fuse will overheat and fail so check this using a multimeter and confirm the element has resistance
Either the heating element used to defrost is bad
or there is usualty a small inline thermal fuse
replace it
test the elements resistance is aok
look on ebay for a new inline fuse and also element save the grief of testing
Posted on Dec 10, 2014
  • Fazal Iqbal
    Fazal Iqbal Dec 10, 2014
    The issue started with not enough cooling in fridge and freezer both. And as per troubleshooting steps i opened the back cover and cleaned all dust and found fan by compressor not spinning so i got that replaced and since the unit was kept off all night, it was fully defrost and upon turning it on it started working for week and same issue again. Thought it might be sensor and start reaearching for parts and found DA32-00006W which is the upgraded version of DA32-00029A. As the panel in the freezer was opened i found the heating element to be in pretty bad shape with rust and a broken wire in one of the glass tube.To save time and avoid testing headache, i went a head and replaced freezer sensor, thermostat sensor and heating element which was obviously bad and motherboard.
    It has been two days and so far no issues. I will post further if i find any issues. Hope this $130 parts investment will last another 4 to 5 years.
    Thanks
bobotfel
  • 236 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
tborn6
  • 700 Answers
SOURCE: Evaporator coil frosted up on Samsung RS267LABP Refrig side
TAKE AND DISCONNECT THE POWER TO TH UNIT AND ON THE VERY BACK THERE IS A CONTROL BOARD THE IS UNDERNEITH A WHITE PLASTIC COVER THAT YOU WILL HAVE TO REMOVE THEN DISCONNECT AND RECONNECT THE WIRES TO THE CONTROL BOARD AND SEE IF THAT DOESTHE TRICK.
Posted on Mar 07, 2009
  • 500 Answers
SOURCE: My Samsung RS2534 side by
Hi mminottoi2004,
It uses a defrost element, built into the evaporator to melt the ice once every 1 - 2 hours. I suspect one of the sensors are failing, or the defrost element is faulty or worse.
You can test the defrost element with a decent multimeter, make sure power is getting to it, in at least 1 to 11/2 hours. If no power ever reaches the element, even when the compressor shuts off, then more likely the problem is the PCB. If power does reach it, but it does not get warm, the defrost emelent needs replacing.
Testing sensors on Samsung models are nearly impossible, so I am not even going to advise it. The resistance readings never make sense.
So in a nutshell: 1) Faulty Defrost Element or 2) Faulty Sensors or 3) Faulty PCB.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Posted on Aug 15, 2011
espressonist
  • 1711 Answers
SOURCE: how to change Defrost Temperature Sensor Samsung DA32-00006W
We have here a video link that can help replace the defrost thermostat
Posted on Dec 13, 2011
blazinblazer
  • 6 Answers
SOURCE: Samsung bi-metal defrost thermostat
most refriderators have an evap tube on the back of the fridge over time this will get all gummed out and will not allow the water to evaporate cause it to freeze try unclogging this tube with a pen or pencil go slow however you dont want to damage internals by jamming the pen in there hope this helps
Posted on Feb 22, 2014
Samsung model rs2530BWP cubed ice icon is blinking what does that mean
mine was doing this, i replaced the main board and power supply, it was still doing. i checked all the sensors and still didnt fix the problem, i then looked at the ice maker, there is a sensor on the ice maker that has two white wires off it, i used a jumper wire and touched them together at the plug in the freezer and it started working like it should, now i have to order a new sensor from what i can tell. part number DA97-00258E to replace the ice maker.
Oct 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
I need to order compresor fan for my refrigerator
Hi please find some link for you below.. these will assist you.
http://www.partstore.com/Model/Samsung/Samsung/RS2530BWP.aspx
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RS2530BWP
http://www.samsungparts.com/Products/Parts_and_Accessories/RS2530BWP/XAA/Default.aspx
Right, these days in our global market, anywhere is as good as anywhere as long as you are aware of what you are getting. Always try to obtain original parts, but if not possible, then make sure you have a warranty.
Jul 04, 2011 | Samsung RS2530BWP (25 cu ft) Side by Side...
Why do i have to press the reset botton to get the ice to fall, on my Samsung RS2530BWP refrigerator? Also the side panels only on the freezer side are HOT to the touch and im worried it might become a...
Verify that the compressor fan is working. The fan is located behind the unit at the bottom. You need to remove tha back panel and observe that the fan is working while the compressor is running.
Mar 19, 2011 | Samsung RS2530BWP (25 cu ft) Side by Side...
I have a samsung side by side srs537nw. both side are not working properly. the fridge wont cool and the freezer turn into a fridge.
Had exactly the same problem. Found the cooling coils are not defrosting, everything was iced up inside the back panels. The drain was blocked, water pooling underneath also.
Remove all the plastic panels in the back of the freezer, including the temp. sensor (unplug) and fan (unplug). Defrost everything with a hair drier.
Make sure that the drain at the bottom is free, a small plastic tube which takes water down into a pan where it is evaporated by the compressor etc.
Replace the defrost sensor - the most likely faulty part. This costs about $Au 20.00 from Samsung (just ask for a defrost sensor for the model of fridge). This sensor fits in a plastic cage attached to the top of the cooling coils, has wires which plug into a socket. Reassemble the fridge and see if this has solved the problem.
If the fridge still does not defrost automatically, you may need to replace the circuit board ($Au 80.00 from Samsung). This board is found from the back of the fridge, in a plastic box behind a back panel at the bottom of the back of the fridge. Lots of wires to unplug!
There may be other problems, like a faulty thermostat on the valve which controls circulation of cold air into the fridge from the freezer, I have no experience of solving this.
Samsung mechanics are HOPELESS in my experience, replacing the two parts above will be less expensive than a call to them. Good luck!
Feb 10, 2011 | Samsung RS2534 Side by Side Refrigerator
My Samsung side-by-side two door RS2530BWP refregertor is not cooling enough. In side the Freezer, there is lots of snow like ice deposite at the back wall. IT is not making ice. Refrigertor side, it is...
you will need to use a blow dryer and defrost the back wall.Once that is defrosted then you will need to remove the back panel and defrost the evaporator coil.
There are several things that can go wrong the temp thermostat,defrost thermostat,defrost heater,or control board.you will also need to check the evap fan and make sure it is working.
Dec 19, 2010 | Samsung RS2530BWP (25 cu ft) Side by Side...
On the refer side we are getting a temp. reading of 67 degrees at the top as you go down it gets cooler to were in the crispers it is 33 degrees, have changed the thermistor and the evap fan motor what...
It could be a problem with the air damper but.... I doubt it.
Down load this manual and go to page 29 of the pdf file,
http://www.servicematters.com/maytag_library/docs/SAM0074.pdf
You will see this:
Self-Diagnostics in the normal operation
2-1) To select this function, press Power Freeze and Power Cool buttons simultaneously for 8 seconds with an audible
tone.
2-2) In the self diagnostic mode, only corresponding LED segments will be illuminated (see the check list on the next
page)
2-3) After a 30 second illumination of error signal, the system will return to the normal operation.
Note the position of the LED in the temp windows and the side that it appears on. Then see the Control panel LED legend along with the corresponding position legend listed below listed on page 30 for interpetation. This should tell you what has failed.
Make sure to read the Details of each failure on page 30 also.
This is the legend.
NO Error
01 ICE MAKER SENSOR
02 REFRIGERATOR SENSOR
03 REFRIGERATOR DEFROST SENSOR
04 REFRIGERATOR FAN ERROR
05 ICE MAKER function error
06 CoolSelect ZoneTM SENSOR
07 REFRIGERATOR DEFROST ERROR
08 EXIT-SENSOR
09 FREEZER SENSOR
10 FREEZER DEFROST ERROR
11 FREEZER FAN ERROR
12 CONDENSER FAN ERROR
13 FREEZER DEFROST ERROR
Run the test and let me know what the test indicated.
Thanks for choosing FixYa.
Kelly
Sep 29, 2010 | Samsung 26 Cu. Ft. Side-by-Side...
Refrigerator side not cooling freezer works fine
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ghjghd
Jun 28, 2010 | Samsung RS2530BWP (25 cu ft) Side by Side...
Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Jan 05, 2008 | Refrigerators
Samsung RS2530BWP (25 cu ft) Side by Side Refrigerator Logo
89 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
