Question about Westinghouse Electric Ceiling Fan Light Switch By Westinghouse 77023
My westinghouse fan is making a beeping sound that I can't seem to turn off
I have switched the main fuse for the lights and the beeping stopped but as soon as I put the power back on it started beeping faster. It starts and stops randomly and can stay on for hours.
Oven has stopped heating, and automatic interior light has also stopped working. Fan still works though - any ideas?
Stove possibly has a fuse panel which is usually in the inside area of the switches and there is usually one for each burner as well as the oven. Make sure you replace with the right size fuse or you could have trouble.
May 18, 2015 | Ovens
Fan to cool my car seemed to stop working where is the fuse in the fuse box I have a 1999 Toyota Solara
Turn off ur car before u work on replacing any fuses. Find the main fuse box by looking under the hood in the engine compartment.-----------------------------------------------------------------------------------------
Car Key Programmer
Jan 23, 2013 | 1999 Toyota Camry Solara
My PC when plugged in does not turn on but only powers the fan
Is there beeps coming from inside the tower case? Does the Hard Drive make a spinning sound after about 15 to 20 seconds? It could be a mother board issue, it could be a graphics card issue.
Jan 17, 2013 | Packard Bell Computers & Internet
My ps3 wheni go to turn it on n press the button the lite goesfrm green rite back to red n wont turn on
This fix works for some models, so if it does not work for you please tell me your model number
Look at the bottom. This is what it looks like:
SONY
PLAYSTATION 3
CECH-*** = Your model number
SONY COMPUTER ENTERTAINMENT INC.
MADE IN XXXXX
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it, it will beep
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and blink a red light.
When this happens, turn the main switch off and on then turn it on normally.
Let me know how this goes!!
P.S. It will not harm your ps3, It's testing the cooling fan.
Nov 28, 2011 | Sony Playstation 3 (PS3) Console
Red light blinks and wont stay on when push power button
While holding the eject button, turn the main switch on, when the power light is green, release it and you should hear a beep.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and the red light will blink. When this happens, turn the main switch off and on then turn it on normally.
Tell me how this goes!!
May 05, 2011 | Sony Playstation 3 (PS3) Console
Remote stopped working, fan and light do not
click the reset and turn off the fuse box and then turn on
Feb 15, 2010 | Casablanca Fan 3245T Ceiling
Westinghouse 33001 won't turn on power pack has green light could it be a fuse or a switch that needs to be reset?
The green light means the 5v standby circuit is working, yes it can be a fuse for the main power supply section that gets the control signal from the main board to turn on, so it can be the main power supply or the main control board.
Nov 03, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
My westinghouse flat panel has lost its picture and sound. The blue light comes on but nothing...The power button will turn on the blue light but will not turn it off. The remote will turn on the blue...
Hello, It seems you might have to replace the main board on your unit since the board is not booting up all the way and it is also jamming the signal. If you are interested in obtaning the part please email Westinghouse parts at parts@@wde.com for price and availability of the main board.
Oct 27, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Westinghouse Electric Ceiling Fan Light Switch By Westinghouse 77023 Logo
47 people viewed this question
Top Westinghouse Electric Electrical Supplies Experts
AJMAL KHAN
Gene Haynes
Terry Weaver
Terry Weaver
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
