Question about FelPro 1946 - 1954 Studebaker Champion Engine Oil Pan Gasket Set OS 4
HOW DO I REMOVE AN IGNITION SWITCH FROM A 1954 STUDEBAKER CHAMOION
NOTHING
    Problem Solver:
  • 19 Answers
Check here: http://www.studebakerdriversclub.com/index.asp
Posted on Dec 08, 2014
How to remove gas tank from a 1954 ford f100
moved you out of JEEPs.
(drain it)
unhook all lines and hoses
then with jacks holding it up.
unstrap it (bolts)
lower jack and BINGO.
Jul 05, 2014 | Ford Cars & Trucks
1999 International 4700
IF you are talking about the lever switch ,, many have a PLASTIC switch piece in the steering wheel , which have so called hooks on them..... that when you pull the lever , it engages into that hook and turning wheel / cornering or just moving the lever back to it's neutral postiion turns it off........ thus needing to remove the steering wheel to replace / fix it .
1st check with your local parts house to see if there is this piece in your year / make / model.
Apr 12, 2014 | 2003 Avanti Studebaker
How do I remove the seat in a 1954 gmc truck
It just unbolts front and year and lifts out.
Jun 14, 2012 | Cars & Trucks
Lost my 1954 singer sewing machine manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 1954 ) & click search
if search comes up with nothing, then contact singer customer service
Mar 04, 2012 | Singer Sewing Machines
Generator for a 1954 Studebaker is not charging.
No, every other one of the commutator contacts should be connected. In other words, if there are 12 total, 6 will have continuity with each other and the other 6 will have continuity with each other.
One brush is positive and one brush is negative. The negative brush lead will usually ground to the generator case. The positive lead will go through an insulated stud in the case, connect to a wire and run to the voltage regulator.
If all the commutator bars have continuity to one another, the commutator is shorted and no good.
Hope this helps, let me know.
Regards,
Apr 08, 2009 | Chevrolet 1500 Cars & Trucks
I put a in line 6cyl. 250cu.in. in an old studebaker.I was told it came out of a 76 C-10 pickup.I used the wiring harness which came with the motor.How does the external coil get power.There are 4 prongs...
It would seem that you got an engine with an ignition control module (ICM) type (electronic) ignition. You will need to find a wiring diagram and see where the ICM unit fits into the system and what else it may need to work with your Studebaker.
You may want to consider changing to a breaker point distributor to simplify the installation. You will need to get a different coil and add a ballast resistor if the Studebaker didn't have one (but I suspect it has).
Jul 03, 2017 | Chevrolet Chevy Cars & Trucks
FelPro 1946 - 1954 Studebaker Champion Engine Oil Pan Gasket Set OS 4 Logo
80 people viewed this question
Top FelPro GPS Experts
Are you a FelPro GPS Expert? Answer questions, earn points and help others
