Question about Dryers
Hi, We have Sanyo PTAC STW 1223C2P,in real cold night, heat stripe in not working proper, on left side blow cold air, in center throw hot air, is heating element bad? or at the end small thermal fuse blown? if it is bad, where can we buy from? and how to replace it. plz help us.
TheMobilian
  • 8220 Answers
SOURCE: how do you test dryer heating element on GEQ9800LW0
Ok maybe the heating element got old and brittle over time and finally gave up the ghost. But it may not be the element. It could be one of the safety Hi-limits have blown.READ MORE...
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 10, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: No heat from my tumble dryer
There should be 2 limits mounted above the heating element on back along with a limit mounted on the heating element. I have some repair video: HERE
Posted on Feb 16, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Performa dryer blowing heating elements
Hi and welcome to FixYa. You should check the dryer vent ducting inside and outside the dryer for restrictions / clogs to include the vent flapper. Poor air flow through the dryer will cause hot spots. If the blower is slipping on the motor shaft this too can cause poor air flow.
When you change the heating element AGAIN... break out the crevice tool and de-lint everything you can access. Also pull out the lint filter and wash it with white vinegar and water then soap and water. Fabric softener sheets material builds up on lint filters. It looks clean but air will not pass through the lint filter.
I think once you get it all ceaned up including all of the ducting to and through the outside wall it will work normally with no problems. I do not think at this time that you have an electrical problem with the outlet supply.
There is one more thing to check and that is the high limit thermostat. It could be STUCK. It will most likely be labeled L180 or L190. That thermostat is suposed to open at either 180 deg or 190 Deg depending on which one is installed. If it does not open then you will keep cooking your elements. We test them with a match and an Ohm Meter. Match under the removed thermostat CLICK. Thermostat opens (no resistance)
Wish ya the best.
Thanks for using FixYa.
Kelly
If anything in the future crops up with this same issue.
Posted on Apr 10, 2010
TheMobilian
  • 8220 Answers
SOURCE: Thermal Fuse Blows in Whirlpool Cabrio Dryer I
You got 2 thangs to look at. Bad heat control AD air restrictions.
Service Manual
Posted on Nov 07, 2011
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Heating and AC Temperature and Air Delivery Mode Do
Jan 16, 2016 | Toyota Cars & Trucks
This question for Sanyo PTAC HVAC for Hotel-Motel style unit.Hi, We have Sanyo PTAC STW 1223C2P,in real cold night, heat stripe in not working proper, on left side blow cold air, in center throw hot a
If you are saying this happens on a really cold night, the assumption is that on milder nights, it seems to work adequately.....If that's the case, there is a possibility that it is marginally sized in capacity to heat the space in which it is installed. If it has a "fresh air" damper setting, make sure that is closed completely, because that is air directly from outside the structure that is being brought in through the blower and adds more load to the space and makes the discharge air feel colder.
Dec 08, 2014 | Dryers
Cold air coming from passager glove compartment making the front ducts blow out warm not hot
There could be cold air coming in because the air vent is not closing properly when it is suppose to close.
Oct 04, 2017 | 2004 Ford Explorer
Heater core is working properly but car will not blow hot air only cold air i am thinking the flapper that controls hot \ cold is stuck in the cold air position
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
Jan 25, 2012 | 2001 Buick LeSabre
The ptac unit is not heating or cooling the aux heat works the line out of the compressor gets hot but the line going to the coils up front does not get real hot just warm and does the same thing on the...
Verify all your components are operating - Compressor? Condenser fan motor? Blower fan motor?
If not check voltage to any that are not operating.
If all components are operating and the coils are clean - the refrigerant level is most likely low.
Oct 28, 2010 | Amana PTH153B50AJ Heat Pump Air...
2007 Chevy Silverado dual climate control, even if passenger side is not on it blows cold air on passenger side and hot on driver side when in heat mode, also noticed cold air on driver side when A/C is on...
Just had this happen today to my 2007 silverado heat on the right side cold air on the left side. After engine was off 15 minutes and restarted heat was on both sides. I'm guessing a relay failed to open door to allow the heat to flow thus blowing cold air.will monitor diligently for a while.
Oct 20, 2010 | 2007 Chevrolet Silverado Classic SS New...
Driver's side air blowing warm, won't change
Sounds like there is a crack in the vent that leads to the drivers side, and hot air from the engine is leaking through.
Aug 29, 2009 | 2003 Hummer H2
Dryers Logo
Top Dryers Experts
