Question about Ingersoll Rand Air Tools & Compressors
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
MODEL:SM75 INGERSOLL RAND SCREW AIR COMPRESSOR
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 22 Answers
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Posted on Jan 03, 2015
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
rockitman187
  • 2559 Answers
SOURCE: After removing and replacing a completely shredded
It sounds like you have a valve floating.
Posted on Feb 22, 2009
  • 2976 Answers
SOURCE: My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Posted on Aug 08, 2009
louislevel_2
  • 374 Answers
SOURCE: capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
Posted on May 08, 2010
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
Hello. I have a Ingersoll Rand air compressor, model 2475. I was wondering if there was a way to adjust the pressure gauge to create a larger differential. It is currently running between 150 and 160...
You can adjust almost all pressure switches
Compressors,Well Pumps,etc
Take off the cover & there should be a screw
to do just what you want to do,lower the cut out
pressure
Good idea, as the compressor will last many years
longer, the less it runs
Jun 29, 2011 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Dec 04, 2009 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Sep 11, 2009 | Ingersoll Rand - Rand Type - 30...
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Nov 12, 2008 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
165 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
