Question about Sony VPL-EX5 Projector
Pannel is locked and red light is on
I have tried to on but the display is not coming.
    Master:
  • 373 Answers
Check for bulging capacitors on the power supply board. Replace if found.
Posted on Dec 10, 2014
The display on my oven is not working at alll!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
mine did the same thing. the contol pannel is bad. sears.com has a replacment pannel. here is the parts number. 5765M433−60
if the door is locked then try the unlock metod. it also will lock the screen from working. press and hold both cancel-cook&hold buttons at the same time for 3 seconds. if it works your in luck. if not it will cost 190.00 for a new pannel. cheers.
Dec 21, 2010 | Maytag MEW5530D Electric Single Oven
I can not run my toshiba power saver nither can i change my power settings manualy. I cannot find where the tishiba power saver option is iv already checked control pannel.and one mor thing, the infra red...
the infra red i dont know anything about, sorry. the power settings, most of the time are in control pannel .
if you haven't already solved your problem, try going thru
'control pannel', then ' performance & maintenance',
then 'power options'. anyway, thats where mine are located so maybe you'll get lucky and solve one issue. good luck!
Feb 09, 2010 | Toshiba Tecra M1 PC Laptops
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Red light on the cotrol pannel has come on. what
this means that temp is below -18 deg Celsius,and probably compressor is not good,or gas is leaked.
Jul 02, 2009 | Kelvinator Freezers
I can not get the time off of the front display
Hi There,
Try unplugging the TV for 2 minutes then plug it back in. Let me know what happens.
Mar 14, 2009 | JVC AV-32D305 32" TV
TV won't power on, repeating doulbe red light blink
Question Television is not working, screen is black, blinking red led.
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Whirlpool Duet WFW9400S - Nothing works but lock button
YOU HAVE A PROBLEM WITH THE CONTROL PANNEL. REPLACE CONTROL PANNEL AND YOUR PROBLEM WILL BE RESOLVED
Jun 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No display on front pannel
I had this same problem. I solved it by connecting both yellow and red power supply cable coming from player to only yellow cable from my car. There was also red wire coming from car but things didn't work that way. I can't say I knew what I was doing so try on your own risk.
Mar 10, 2008 | Sony XPLOD CDX-GT200 CD Player
Compaq Persario V2000 Black (very dark) Display
Hello Bigkahn, The problem you have is related to the power inverts that powers on a small fluorescent light on the bottom of the actual LCD pannel. The "display" is composed of mainly 2 parts. One is the TFT active matrix that is build up by using many transistors. There are 3 of them for each pixel, each transistor displaying one basic color (RGB code red-green-blue) and 3 of them, like i said, forming a single pixel. They don't produce light by themselves they only filter the light that pass through the TFT pannel. So if a transistor displays "green" it will do that by filtering the light that comes from the fluorescent lamp i was talking before. It produces white light so therefore the transistor pannel will filter the coresponding wave lenght to block anything else than "green". (white light is a combination of all spectrum lenghts) Therefore in your case, if you light up the display using an external light, you may see something on it because the pannel will try to filter the light you give to it. This shows that the actual transistor matrix is working. Your problem is like i said, related with the power inverter. It'a small device inside your laptop that will raise the tension given by the batteries to about 2-3000volts needed to fire up the fluorescent light (some kind of "neon"). If it doesn't work that light woun't come on and the display woun't light up therefore the transistors on the pannel woun't have anything to filter and display on the screen. This problem can happen because of either a faulty connection between the inverter and the fluorescent lamp, or the inverter to the mainboard. Another cause can be the hardware failure of the actual inverter that is preventing it to raise the tension to the specified values. Either of these will require you to have your laptop checked at a service center because we are talking about tensions ranging 2-3000Volts and sensible component. This shouldn't be an expensive repair because the actual pannel (the screen) is working fine and all that needs to be done is to check the inverter or replace some components relating to it. If you have further questions please feel free to reply to this. Good luck.
Apr 04, 2007 | HP Compaq Presario V2000 Notebook
Sony VPL-EX5 Projector Logo
64 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
