Question about Canon CANNON IR 3530 COPIER FOR 220 VOLTS ONLY
How to fix ir3530 error in ir3530
Fixing problem
  • Andy Brasfield
    Andy Brasfield Dec 08, 2014
    Hi Vinay Bubby, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
2 Suggested Answers
SOURCE: my canon ir3530 shows e0007-0000 for every 20 copy
error 225 what sollution
Posted on May 07, 2010
My copier canon ir3530 occured error code E-000024-0001.How to solve this code?
E024 developing assembly connector disconnection fault..this is what it is saying on the internet.
Nov 19, 2016 | Canon Office Equipment & Supplies
Error code SC412
I WHANT TO REMOVE E000002-0000 FROM MY CANON IR3530
Feb 01, 2013 | Office Equipment & Supplies
Haw to find the all night power suply in ir3530
There is No such power supply called "all night power supply". Have you tried to adjust the display contrast on the control panel????/
Jan 13, 2013 | Canon IMAGERUNNER 3530 Copier
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
Cannon ir3530 error code eoooo-oo19 please give me solution
open the front door, remove waste toner tank and clean the toner.
Feb 05, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Canon IR3530 jamming
Hi, lets go from begining:
1) Remove rollers from lower cass, and put them on first cass. Use fresh paper too. - Does it helps? try abaut 50 copies.If helps replace rollers.
FB6-3405 x1, FC6-6661 X1, FC6-7083 X1
2) when you open right lower door and right door you will be able to see axis with two small rollers.Clean it verry well, use alcohol.
3) On lower right door there must be metal plate for pressure on delivery roller, if there is no plate, put in each corner some tape or filc 2-3mm thick, wich will add pressure on plastic paper cover wich guides paper on delivery roller.
4) Does your jamed paper have any anomalities on itself, like: look like accordian, small wrinkles,...
If yes, check separation plate on fixing unit, pressure of rollers ( between fixing film and press. roller - NIP CHECK ).
5) Beaneath drum you will see small plastic sensor flapper - is he worn out? This is paper registration sensor, if he get in first position before the paper pass him you will get jam code.
Note:
Try to flip paper in cassete, up side down, and try then. If then works, the problem is in moisture on paper.
Hope that helped
Jun 29, 2010 | Canon ImageRUNNER 3570 Copier/Printer
My canon ir3530 shows e0007-0000 for every 20 copy. done fix -cln and clear the error but no result
Plz check fixing film when u open fixing unit u find a white color sensor plz clean it with clean cloth or if your film is torr then u need to change it with new
Apr 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir3530
As far as I know this machine comes fitted with a network adapter already and all that needs to be done is for you to purchase the license (this comes as part of the PCL or PS Print Kit) to enable the printing feature. I know with some models an additional memory DIMM also needs to be installed. I'm not sure if this is one of those models, but in the event that it is, the DIMM is also supplied with the print kit and it is accompanied by a complete set of installation instructions
Sep 23, 2008 | Canon imageRUNNER C3200 Copier
Canon CANNON IR 3530 COPIER FOR 220 VOLTS ONLY Logo
27 people viewed this question
old marine
old marine
