Question about Denon AVR-1706 Receiver
I have a Denon AVR 1709, that has been lying unused last 2 years, recently I reinstalled and auto set upped, it is detecting all speakers and Subwoofer, but no out put sound is coming when I use any D
Auto set up and system set up
3 Suggested Answers
  • 6771 Answers
SOURCE: My Denon AVR-1709 was professionally
This is a case where the audio output ic's have failed, you describe a popping sound which is a classic sign of total audio collapse. Since this was a professional installation, I recommend a top of the line audio technician with an estimate in mind.
Posted on Jan 07, 2011
Testimonial: "it's bad news, but it is the truth. thanx for your help!"
  • 163 Answers
SOURCE: Hi, I have a Denon
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Posted on Sep 22, 2011
How do I reset my Denon AVR 1709?
with power off - press and hold the "INPUT MODE" & "SPEAKERS" buttons and press power. All display segments should blink. Let go of buttons and reset is complete.
Apr 07, 2015 | Denon Audio Players & Recorders
What will factory reset avr 1709 fix
It will not fix any problems with it, It just sets it back to the way it was before you set it up.
Dec 04, 2012 | Denon AVR-1708 Receiver
Denon Receiver keeps switching between H/P input and speakers
The problem may be dust in the headphone jack
http://blog.adamnash.com/2010/10/01/solution-denon-av-receiver-avr-1410790-with-no-sound/
Jun 17, 2012 | Denon AVR-1709 Receiver
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
Sep 03, 2011 | Denon AVR-1905 Receiver
DENON 1709: The sound is OK when STEREO is setting. Using 5.1 STEREO or MUSIC or CINEMA setting all the speakers are working, except Front Right. I check the volume for each speaker and set it up to the...
The Stereo setting does not use any digital processing and likely avoids the decoding board completely. From your description, either the signal is not being decoded properly or the right channel signal path is being interrupted somewhere. Without taking measurements inside the unit, I cannot tell for sure where the problem lies. Careful examination of the processing board is required here. Take the unit to a repair shop for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair.
Dan
May 29, 2011 | Denon AVR-1709 Receiver
I have a Denon AVR-391.Now it is starting to stop functioning. The set will work then after a while I can not operate any of the commands via remote or manually. The set will not turn off nor am I able to...
If you have had this unit for a while I would try vacuuming or blowing it out because it sounds like the issue you are having is due to heat building up in the unit. Also make sure you have adequate airflow around the unit in other words make sure you have at least 2-3 inches of clearance on all sides and nothing sitting on top of the unit.
Apr 11, 2011 | Denon AVR-1709 Receiver
My Denon AVR-1709 was professionally installed. It lasted less than 2 years, then the speakers started popping, then a few days later there is no signal to any of the 5 speakers or subwoofer. same for all...
Jan 07, 2011 | Denon AVR-1709 Receiver
Denon avr -1709 how do i get it reset to factory specs
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Mar 21, 2010 | Denon AVR-1708 Receiver
Sorround Back Speakers not giving proper output
for surround put zone 2 on. if zone 2 is not on the speakers which you hooked in the surround back left and right wont work
Dec 24, 2007 | Denon AVR-1507 Receiver
Denon AVR-1706 Receiver Logo
53 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
