Question about Tablets & eReaders
HOW DO I REBOOT MY TRIO STEALTH-10 TABLET?
I have pushed power button and volume button same time..it will turn off but when i wait 5 seconds and turn back on..nothing
  • Tablets & eR... Master
  • 5,529 Answers
Hi Joanie, you need to turn the tablet off first then press power and volume+ together!
Posted on Dec 08, 2014
  •  Mikey
    Mikey Dec 08, 2014
    When you reach the factory reset screen, scroll with volume button and enter with power button!
pagebor
  • 2785 Answers
SOURCE: My Tablet PCT4010 Seems dead after forced power off...
please try with another bootable cd.
Posted on Apr 21, 2008
SOURCE: Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
Posted on Dec 09, 2008
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
SOURCE: charged sylvania tablet for 24 hours & unplugged it but no power
Many times the cause of this problem is u need a new piece where the charger plugs into the device because it shorts out.
Posted on Aug 20, 2012
cougar123
  • 77 Answers
SOURCE: the 7 inch tablet when you turn it on shows the 2 dogs then goes to rca logo and nothing else. tried to reset by holding power & volume button at same time, did not work
contact vendor mfg - shoulds be under warranty
Posted on Jul 11, 2014
Can you do a screenshot on the Trio Stealth G2 9.7 Tablet?
This should work on any Android 4.0 and newer tablet.
To take a screenshot on your device, press the Volume Down and Power keys at the same time.
The screen will flash, you'll hear a sound, and you'll see a framed image appear and fade into the notification bar. The "Saving screenshot" notification will appear.
May 10, 2015 | Mach Speed Trio Stealth G2 Tablet -...
My trio stealth is new. When I power it on, goes to a screen "@9dual core" and doesn't go any further. Help!
There's a hard reset process on the G2 7" that I have used successfully on several stuck units. It may also work, I've learned, on other models of Trio tablets and other Android-based brands / models as well. It did on a Zeki 7" 8GB that I owned. But.... TRY AT YOUR OWN RISK. Here it is.
(1) PRESS AND HOLD the power button until the tablet shuts off completely.
(NOTE:
if any type of start-up screen comes on, FORGET it: the Tablet must be COMPLETELY powered off for this to have any chance of working.)
(2) PRESS AND HOLD the volume-down button, while simultaneously PRESSING AND HOLDING the power button
This will (hopefully) bring up the Android figurine, along with some kind of rotating-wheel graphic.
(3) Do nothing else but WAIT, until the screen changes to a text-based menu, with about 6 to 8, or more choices.
(4) Use the volume-up and volume-down buttons to navigate between choices, and select (highlight) the choice offering to reset the tablet (to Factory Settings).
(5) Click and release the power button to start the reset operation. Follow and additional prompts to ensure you are selecting the correct next step.
This RESET process will erase ALL your installed apps, as well as delete all your saved photos, music and other user files and preferences (including wallpaper, time-zones, Wi-Fi settings etc. But when it works it will give you back a working Trio. Use your reset Triot carefully: generally, I'll say the Trio machines are good economical alternatives to the perhaps more robustly engineered (and much more expensive) big brand items.
Regarding restoring personal preferences, and earlier installed apps I have no experience whatsoever. However there may be sufficient arguments to backup your personal data either on your home computer or on online "cloud based" services. Do the research, ok?
Happy New Year, 2015 ... & ....Good Luck!
Dec 28, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
My trio stealth will not go pass the trio screen. How do I fix this?
hold your power and volume up at the same time when it comes on release power button wait 5 sec release volume button you will see sevral ways to restart i had to clear data and ues factory restart just follow promts worked for me
Dec 11, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
My trio stealth 10.1 is getting stuck on the@9 dual core load up screen. what do I need to do to get it to finish loading??
HI Naomi.
I do alot of TRIO fixes. Here is a great youtube walk thru. If it does not work I can try some other fixes but they can wipe out all your settings and data.
Good luck
Chadman TRIO 10 1 g2 Stealth Elite Android Tablet Update 2 Testing Recovery Mode...
Nov 24, 2014 | Tablets & eReaders
My trio stealth-10 tablet is frozen
Press the volume up and power button for about 10-15 seconds to reboot.
Sep 26, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
Why won't my trio stealth g2 tablet won't hard reset?
Does the device have a password lock on it.
If it does try removing this first, then attempt a hard reset.
You can access the engineers menu by holding the volume - button and then pressing the power button whilst turning it on.
Other than that the only other option is to reload the ROM with a flash utility.
But this is not for the faint hearted :-)
Aug 05, 2014 | Mach Speed Trio Stealth G2 Tablet -...
After i connect my trio stealth g2 tablet to my laptop its stop working.how do i fix it i tried to reboot but it just froze up
There is a Hard-reset sequence for all tablets and phones..
Typical on tablets and phones you Power Off and then hold both the power and volume up (for up to 2 minutes on some models)for one menu and/or power and volume down for another menu, then use the volume buttons to move up and down the seclection menu, then the power or home button to select..
If there is a home key, it could be this and the power button.
**Always start this sequence with the power off first.
Typically to turn power off you hold the power button in for 10 seconds.
Some systems, when you hold the power and other button down you must release one of the buttons and continue holding the other.
Should only take a few attempts to figure it out.
IF you don't have any luck there should be several Youtube videos desccribing how to resolve this and other issues.
If yor tablet or phone is unlocked or jailbroken Im not sure to use thiese methods as it may corrupt the data. For jailbroken units refer to youtube perhaps.
Hope this helps, good luck.
East Coast Canada Rocks!
Jul 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
How to reboot a trio stealth tablet?
You can reboot the Trio Stealth Tablet by getting a push pin and inserting it into the reset hole. It's a very tiny hole located on the side of the tablet.
Jul 06, 2014 | Tablets & eReaders
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
Jun 12, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
I have a trio stealth g2 and have been locked out how do you rest to factory settings
1. While the tablet is off, press the Volume Up and the Power buttons at the same time. Let go when the Android recovery screen appears
2. Press the Power button to bring up the recovery menu.
3. Using the Volume Down button, highlight "wipe data/factory reset"
4. Press both volume buttons at the same to select the option.
5. Scroll to and select "Yes - delete all user data"
6. Once the wipe is completed, select "Reboot system now"
Oct 25, 2013 | Tablets & eReaders
Tablets & eReaders Logo
48 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
