Is there a fuse in a detrola km837?
Power surge left me with dead unit. please tell me it can be fixed.
  • 95 Answers
SOURCE: My RV unit got a power surge and the microwave looks dead.
Yes they have fuses, I am positive it's your fuse, take all 5 screw's off and you'll see it at the back on the right hand side were the ac cord goes in.
Regards
Bob
Posted on Jan 20, 2008
SOURCE: need to replace needle or
eat **** muddafuka
Posted on Sep 10, 2008
frenzy19
  • 258 Answers
SOURCE: How to repair..IBM 240 w Powersupply...
how did you know that's the problem is on power supply?what signs did you saw before it happened
Posted on Nov 14, 2008
  • 104 Answers
SOURCE: Need free owner's manual for a Detrola record player Model KM837
unable to follow what is wrong.
are you talking about the tonearm or a lever at the power switch?
Posted on Feb 11, 2009
  • 700 Answers
SOURCE: Dead Set after power surge
If ever the fuse is blown like that, you have a major short on the circuitry. Check first the rectifier diode a by-passing one diode can do this. Also the chopper component may it is a transistor, FET, or regulator IC. Also check the main filter capacitor, shunt resistor.
If ever, you can isolate first the secondary circuit. To troubleshoot first the power supply side. You have to have at least an standby power.
Posted on Oct 01, 2009
I cannot open the CD door on my Detrola KM837 4 in 1. I push the open button, sounds are emitted like it wants to work, but does not. Any suggestions?
agree with a small hole trick... but don't leave the drive ever empty. Use i.e. dummy CD media always. When you need it, just replace, spin your DVD, than put DUMMY back in the drive. Don't believe? Just try. :-)
proizvodnja raunara prodaja laptopova popravka kompjutera pc servis...
Sep 26, 2016 | Computers & Internet
My radio stopped working after a power surge tripped the breaker for the outlet it was plugged into.
I have had several different makes of clock radios and all said that it was battery back up for power failure
none worked and all settings had to be redone
power surges do not trip breakers as they are in effect a fuse to prevent damage to the wiring in a dead short situation or when a unit fails
even surge protectors will still pass power after a surge but will no longer protect against another surge
Sep 04, 2015 | Emerson CKS3528 SmartSet Desktop Clock...
Can i use a crosley stylus in my detrola km837 record player
Stylus will only fit into certain cartridges. You have two options here. You can look up the cartridge number and make on your Detrola. It should be on the cartridge somewhere. Then search for the stylus. Or you can remove the Detrola cartridge and fit a new cartridge and stylus. As long as the cartridge will fit into the arm of your deck, plus it's the right type - ie: magnetic if the old cartridge was magnetic! Or ceramic - again if the old cartridge was...
Then you can use any make or model cartridge you want. As the quality of the sound can be improved - albeit paying more money for it - by having a good quality cartridge and stylus, it might be best in the long run to change the cartridge.
Jul 15, 2015 | Crosley Audio Players & Recorders
I bought a Detrola KM837 second hand for my mom for Christmas, it came with no manual. The turntable I figured out from other posts, haven't tried it but I think that it would work. But my problem is the...
Very often a small belt has fallen off or broken. A look inside should locate it. To find a replacement belt, just measure the diameter of the old one in MM and then put the words "drive belt --MM" into Google. Select the size close to yours.
Oct 27, 2013 | Audio Players & Recorders
I had a power surge in the house and now my GE sensor Microvawe is stone dead. Any ideas.
It is possible the main fiuse in the Microwave has blown. Sometimes this is a special ceramic fuse and costs around $30. But to get to the fuse you have to remove the outer cover of the microwave( unplug it first) It is usually located on Top left side of the unit. Once replaced it should return to service.
Please rate our help++++Thanks for using FIXYA
Oct 12, 2009 | GE JVM1630 Microwave Oven
You have probably done this, but I had same problem on one I was given with no manual. I couldn't get the turn table to turn and by accident I move the arm to the right, away from record and it began turning. Hope that helps.
Feb 22, 2009 | Audio Players & Recorders
Jan 25, 2009 | Crosley CR248 Turntable
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
k24674
