Question about Life Fitness X3 Elliptical Crosstrainer Basic Floor Model
Display says zero across, when I plug it in, and is not working.
Precor efx 546 error.
please follow this steps and fix it. God bless youError 43 - Zero Switch not FoundDescriptionThe C944 and several versions of C96X used a lift position identification system that did notutilize a potentiometer.Instead, it utilized a switch that would be physically actuated by the lift when the lift was in thezero incline position. A revolution sensor counted lifted motor revolutions to determinesubsequent lift positions. In addition two limit switches where used to remove power from the liftmotor if the lift moved outside of it's normal range.When the unit was powered up the lift would start to hunt for the zero switch. It would first go up4% (maximum lowest physical position was -3%) if it did not find the zero switch or it hit the upperlimit switch, it would then go down until did find the zero switch. When the zero switch waslocated it would stop, the system would then know its physical position and be prepared tomonitor the revolution sensor. If during this power up procedure the zero switch was not found anerror 43 would be displayed.Possible Causes1. The lift position actuator does not physically operate the zero switch.2. The lower PCA is bad.3. The zero switch is bad.Possible Remedies1. There are several physical problems related to the lift platform mounting or the plate the zeroswitch is mounted on that can cause the actuator knob to miss the zero switch as it movespast. Repair the lift platform mounting, repair or replace the lift switch mounting plate asrequired.2. The lower PCA provides a 5 VDC power source for the zero switch. You should measure 5VDC across the zero switch when the zero switch is activated. If the reading is significantlylow, remove both wires from the zero switch and repeat the measurement across the wiresremoved from the zero switch. If the reading is still significantly low, verify the zero switchwiring. If the wiring is intact and correctly connected, replace the lower PCA.3. Move the lift to position where the zero is switch is not activated and remove power from thetreadmill. Remove both leads from the zero switch and measure the zero switch with anohmmeter. The zero switch should read very near 0 ohms. While measuring the zero switchwith the ohmmeter, activate the switch by hand, the reading should change to infinite (open).If either of the above readings are significantly incorrect, replace the zero switch.
Mar 15, 2013 | Precor Efx 546 Version 1 Lower Body...
Repair of a 1970s HP calculator: HP 27
Hi the chances are the board has got damp at some point causing it to short the only chance you have of saving the calculater is to remove the case and clean any parts of the board that look coroded but even doing this might not get it working as some part could be damaged and their is no way of replacing these parts also check battery terminals are free from corosion
Mar 08, 2008 | Office Equipment & Supplies
I have a 2000 kia sephia that recently had the dashboard light and tail lights go out. My headlights still work, but my dashboard and tail light don't. Any suggestions?
This sounds like a fuse problem. Check all your fuses. If they are the little plug in blade type, you will need to pull the fuse out and check the metal tab in the middle. You can pick up a test light for a few dollars at an automotive store. If you connect the light across the fuse (most of these have a little bit of metal exposed at the very top) and the light lights, then the fuse is bad. This test works because the fuse has zero resistance and therefore zero volts across it to power the light. If the fuse is bad, then there is 12volts across the fuse and the light lites.
Best of luck, Jim
Feb 23, 2011 | 2000 Kia Sephia
Range controlpad is no working, is showing SA6& each burnershows 56 orS6
Hi and
SA (burners off) is a door lock switch A problem. The switch has to be checked for 0 resistance across the terminals. If it has resistance then there is another resitance check to look ofr 2350 Ohms between pin 5 in plug P4 and terminal N. If the meter reads zero or infinity the lock motor or the wiring to the lock motor is defective. If the meter reads 2350 Ohms replace the electronic oven control.
This is per page 97 of the service manual: (C/P)
http://frigidaireservicetips.com/pdfs/477_5.pdf
Remove power from the range and go to the back of
the control and disconnect the P3 plug. Measure
the resistance between pins 3 and 4. If the meter
reads infinity check the oven door switch and the
wiring to the door switch. If the meter reads zero go
to step 2.
2. Measure the resistance between pins 1 and 3 of
plug P3. If the meter reads infinity switch A of the
lock motor assembly or the wiring to switch A is
defective. If the meter reads zero go to step 3.
3. Measure the resistance between pin 5 in plug P4
Thanks for choosing FixYa,
Kelly
Nov 24, 2010 | Kenmore Microwave Ovens
My kyocera km1820 displays error code c6400
Zero-crossing signal problem
• The engine PWB does not detect the
zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Causes:
- Poor contact in the connector terminals.
- Defective power supply PWB.
- Defective engine PWB.
Check procedures/corrective measures:
- Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
- Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
- Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Sep 24, 2010 | Kyocera Copystar CS-1820 Black and White...
Installed in 2/29/02, The unit stopped working today. Totally dead. I checked the plug (fine), checked the circuit, fine, and power to house is fine.
2 simple things to check: Inside there is a fuse (15 A) check it. Check that the TCOs (thermal cut outs) are closed ie zero resistance across them.
Oct 28, 2009 | Whirlpool GH7145XF Microwave Oven
Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Feb 19, 2009 | Sub-Zero 642
Casio cash register te-m80
Remove the wall plug and the batteries at the same time, wait ten minutes, put the batteries back first and then plug it back in and turn the key to Reg, you should see a row of zeros across the display as the machine resets itself.
If this doesn't happen the machine is dead and that is very unusual for a Casio.
Aug 21, 2008 | Casio Parts Cash Register PC Desktop
Display lights
hi follow this and see
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Aug 17, 2008 | Zanussi ZWF1430W Front Load Washer
Life Fitness X3 Elliptical Crosstrainer Basic Floor Model Logo
47 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
sajeel1978 .
Level 1 Expert
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
