Tcl29e11 standby on but wont open - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,599 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 08, 2014
RCA TV wont start
Could be an open internal fuse or power supply failure
Apr 12, 2017 | RCA Televison & Video
Silvanya LC321SS9 B standby led... wont turn on
Nov 18, 2016 | Sylvania Televison & Video
I have a 42" Proscan standby light comes on but the tv wont turn on
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo
Aug 26, 2012 | Proscan 42LA45H 42 in. LCD TV
Wharfedale dvdr24hd169f stays in standby no displays wont accept commands
The problem is in the power supply board, often caused by a defective capacitor that becomes open, cap value is usually around 1000uf and sometimes shows a bulge at top leaking contents, if you are handy with a soldering iron replace part with identical value and voltage rating and observe the polarity.
Jun 09, 2012 | Wharfedale Televison & Video
My sharp aquos TV wont turn on. The green power or red otc lights on the front wont turn either. Any suggestions?
Aside from opening and checking fuses and power board here is some general info:
I see so many here with no sound/nopicture issues:
ISSUES:
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
May 27, 2012 | Sharp Televison & Video
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
Sony Wega KDP-57WS655 Standby light blinks 9 times and wont turn
Service Manual of KDP-57WS655 says if TV standby light blinks 9 times then problem is Zero Corssing Detector and you need to replace diodes, D6116 or D6301 which are open on G Board.
Nov 24, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Standby flashes 9 times
the 9 flashes means your Diode D6116 or D6301 is open on G board and needs to be replaced ...and your chassis is Ax-1x
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Tv wont go from standby to on....
I SUGGEST TO CHECK THE INTERNAL FUSE , IT MAY BE OPEN
Dec 06, 2007 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
