Question about Hoover F5906-900 Upright Steam Vacuum
Upholstry attachment no suction when upholstry hose is used. Plastic adapter has been removed as instructed, still no suction?
  • Anonymous Mar 16, 2014
    how do I prime the upholstry cleaning supply hose?
    President:
  • 1,673 Answers
Check to make sure that the hose hasn't cracked, where it hooks up near the motor. If so, replace the hose.
Posted on Jan 06, 2008
How do you attach the upholstry attachment to your hoover steamvac
The hose hooks into the dirt bucket on the front where a clear plastic block sets. Put the hose in that slot and then hook the tube for the water at the top of the hood.
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Will not spray water
After the last use did you run a FULL tank of HOT water throught he machine to clear the lines and the pump? If not the soap has clogged one of the two. If it is the lines simply remove them (one at a time is less confusing) clear them and all is good. If it is the pump (white L shaped object back left corner of machine as you face it) you will have to go to a local vacuum repair shop and order the part.
Apr 14, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Portapower hose won't stay on, when it does poor suction.
In reply to the problem you have about the hose not staying attached very well, we had this problem years ago with one of our old cylinder vacs. Sometimes after several years of the hose connector being rotated to attach/remove it from the machine, the lugs that lock it into the hole can wear down or become mis-shapen as they are only made of plastic.
I have a UK model Hoover Portapower and luckily have never had this problem as I hardly remove the hose at all (except when emptying the bag). If you remove the hose from the machine and have a look at the connecting part of the hose where it attaches to the machine, there should be two lugs/clips either side of it. If these lugs look a bit mis-shapen or the plastic on them looks worn, then the hose will not fit the two slots either side of the hole on the inlet fully hence the hose being loose. The only way to cure this problem is either put a little bit of electrical tape on them which will stick the hose to the machine better as that's what we did. Overall though you are probably best replacing the hose for a new one if this is the case as these lugs will then be the correct shape to fit the machine properly on a brand new one :)
Mar 04, 2009 | Hoover Portapower C2094 Bagged Canister...
I have borrowed a kirby from my friend and i would like to wash my couches, please would you be so kind as to assist and let me know what tools i would need to use to be able to do so??
You need the upholstery attachment (it looks like a trigger sprayer with a plastic jar attached)You MUST have the foam screen that fits on the front of the trigger,without it,you will only get solution.The trigger sprayer fits on the end of the hose.The other end of the hose fits on the blower end of the machine.You must remove the bag,and attach the hose at this end.The trigger sprayer deposits the foam,and you work the foam in with a soft cloth or brush.When dry,switch the hose to the suction side,and vacuum out the foam.There is also an adapter (about the size of a styrofoam cup) that attaches to the front of the machine to allow it to be used when using the hose on the blower (bag) side.
Dec 14, 2008 | Vacuums
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 animal bagless
You probably have a blockage somewhere in the hose or in the base where the hose goes in. Remove the plastic tube at the base of the hose by simply unclicking it and remove the obstruction.
Nov 07, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover steam carpet and upholstry cleaner
I have a model F6211. On mine you have to remove the hose caddy and the door is under it.
Hope it helps.
Oct 11, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Shampoo attachment
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. Now, put the shampoo gun on the end of the hose and you're ready to go.
Instruction manuals available in DVD, VHS or book format by following this link,..
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQcolZ4QQdirZ1QQfsubZ7656839QQftidZ2QQtZkm
Hope this helps...
Aug 09, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hoover z400 clogged
There should be a bottom plate covering the brush roll that you can remove, if you can't dig out the what is in there, try using your hose and suck it out from the bottom, maybe you will be able to get it out.
Mar 05, 2008 | Hoover F5858-910 SteamVac Vacuum
Hoover Agility, No Suction!!!
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Oct 04, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F5906-900 Upright Steam Vacuum Logo
71 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
