Question about Garmin nuvi GPS
I was told I had to turn off my gps after installing updates and turn back on and then reconnect to my computer but my gps keeps saying loader loading
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
I'm guessing Garmin. Sounds like an update was attempted. Your only option in my opinion is to turn off and restart update.
Posted on Dec 16, 2014
  • 24 Answers
SOURCE: problems installing new software
have you checked to make sure the gps is in data transfer mode? menu/active setup/ data transfer
Posted on Dec 06, 2007
  • 52 Answers
SOURCE: StreetPilot c340 will not turn off
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get teh unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Posted on Jul 18, 2008
SOURCE: My gps is frozen and wont turn off or respond
took face plate off and reset button on left fixed it Thanks
Posted on Aug 27, 2008
goalie39
  • 469 Answers
SOURCE: My GPS is locked when I tried to update the maps.
Remove the coloured bezel from around the screen, there you will find the reset button.
Hope this helps.
Ed
Posted on May 19, 2009
SOURCE: Garmin Nuvi 265WT says loading loader
I left my GPS on and unplugged over night (I upgraded at 6pm) until the battery died. When I plugged it in to charge this morning it worked just fine with no problems.
Posted on Jun 06, 2009
Will not let me enter an address.....shows NO MAP DATA AVAILABLE?????
update failed or was corrupt or memory failed or wiped just reconnect to pc an let it update again
May 09, 2015 | Garmin nuvi 1100LM 3.5" GPS w/ Lifetime...
Can not put an address in garmin nuvi
Try running an update with Garmin Express, let it sit for 30 Min after it says it is done, then check again
otherwise you may have jsut installed a smaller region ,... again Garmin express could help.
Aug 04, 2014 | Garmin nuvi GPS
How do i update my gps
A GPS will help find the shortest and fastest routes to a particular destination. When the maps are out of date, the GPS may not be able to find the best route. A GPS should be updated at least once per year. Some GPS manufacturers will allow the user to download free updated maps; however, many manufacturers require the user to purchase updated maps. Updating a GPS map isn't complicated, and will take about 2 hours to install.
1.Turn on the GPS and plug the USB cable into the USB slot located on the GPS.
2.Plug the other end of the USB cable into the USB slot on the computer.
3.Insert the map update DVD into the computer. If you have a map download, locate and open the file on the computer.
4.Click on Update Firmware located on the main menu. Click "OK" when the firmware is finished updating.
5.Unplug the USB from the computer and turn off the GPS. This will allow the firmware to reset on the GPS. Turn the GPS back on and select the language and time.
6.Reconnect the USB to the computer and click on "Update Map," then click on "Load Maps."
7.Connect to the Internet by clicking on the activation link. This will display the activation number. Find the serial number located on the back of the DVD. If you downloaded the update, a serial number was provided. Enter the serial number and activation code into the update program to continue updating.
8.Close the program after it has completed the update, and unplug the USB from the computer and the GPS. Turn off the GPS to finish the update.
I hope you find it very helpful. Thank you for using fixya.
Aug 20, 2011 | GPS
Jun 06, 2009 | Garmin Nuvi 255 GPS Receiver
Frozen screen and it says loader loading
Press the reset button - you'll find it on the lower right of the Nüvi 255, but it doesn't look like a button. It's basically the sticker with all the information on it. It's just enough to push the sticker carefully with something small, not too sharp so it doesn' get destroyed. The Nüvi reboots, the loader loads and proceeds with the software load. Once this is over, shut down the Nüvi and reconnect to the PC. Then, everything works fine (it did at least for me).
Feb 02, 2009 | Garmin NUVI 255 PERSONAL GPS Device
Hope this helps!!
Jul 11, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Map update 2008
you will need to install the usb driver which should be located on the 2008 disk. When you attach the gps to your computer it should ask where the usb driver is located. If your dvd drive is (D) click browse and go the disk and find usb driver folder. I have purchased the new 2008 disk and had problems with it freezing on loader loading. I then browsed the disk and downloaded and then was able to get to the maps. I did not install it due to it asking what map I want to download. I wanted the whole thing so needless to say I am taking it back to walmart. I hope this helps.
Dec 27, 2007 | Garmin StreetPilot C330 GPS Receiver
Problem with garmin c510 st pilot
the update will not load... i had this problem.. i just took the memory card out and re-started the unit... works fine again... Dave
Aug 03, 2007 | Garmin StreetPilot c310 GPS Receiver
GPS Logo
82 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
