Question about Apple iPad 32 GB WiFi Tablet PC
Can't get my iPad 2 volume to turn doen
I have gone to setting and tried to fix it by going to sounds but still can't get it to. Turn down. Tried button on the side of ipad.
  • Apple Master
  • 2,119 Answers
IPad Volume Control How To Video Guide
If this doesn't work ??????
Posted on Dec 08, 2014
  • 128 Answers
SOURCE: My iPad won't turn on. First it would not turn
just take it to an apple store they will be able to fix it and if they cant they will give u a replacement...
Posted on Sep 06, 2011
  • 1099 Answers
SOURCE: have just purchased an ex display ipad 4 and trying to reset to factory settings
You can do this using itunes go to http://ipad.about.com/od/iPad_Guide/ss/How-To-Restore-An-iPad-To-Factory-Default.htm it will show you how to do it. Hope this helps.
Posted on Mar 02, 2013
  • 15 Answers
SOURCE: why is my d2 ipad frozen
I'm sorry but do you have an iPad or an Android Tablet? Android won't run on an iPad as it uses iOS operating system not android.
Posted on Jun 16, 2014
  • 4 Answers
SOURCE: How do I get the sound on my ipad apple 16gb
Go into settings: notification center : check your apps to make sure the sound is on for that app.
Posted on Sep 15, 2014
  • 268 Answers
SOURCE: Just upgraded iPad 3 to iOS 8.1.1. Now everything freezes up. iPad won't even turn off at all. Is there anyway to reverse an update?
Sorry for the update problem. I am glad to tell you that I found an article that collects the common iOS 8 update problems. Hope it works. The Most Common iOS 8 Problems and Solutions iMobie Guide
Posted on Nov 25, 2014
Music sound is gone when I play my iPad mini
This can only be one of 3 things:
1) iPad needs a reset - Press and hold the Sleep/Wake button until the red slider appears. Drag the slider to turn your device completely off. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
2) Toggle the 'Silence' switch on the side of the iPad and turn up the volume
3) If the above two doesn't work, then it is most likely that your speaker isn't working.
Sep 27, 2015 | Apple iPad Mini
How do I get sound on candy crush ipad 2
You sure you want sound? Its the same repetitive 6 second whistling looped over and over. Usually one you start the game you just turn up/down the volume using the buttons. Unless there is an in game mute. Possibly a side switch like on the iphone.
Sep 26, 2014 | Apple iPad 2 Wifi 16GB
Sep 15, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I can't get sound on my iPad mini
try turning the volume up. My iPad mini seems to have a lower volume level than my iPhones. The external speakers are almost inaudible unless turned way up, so I mostly use ear buds on it. But be careful using the earbuds! turn the volume down and gradually increase to a comfortable level,
Aug 21, 2014 | Tablets & eReaders
No sound on ipad
1. If you have no sound at all, even in the Music App, try rebooting the iPad.
Reboot the iPad by holding down on the sleep and home buttons at the same time for about 10-15 seconds until the Apple Logo appears - ignore the red slider if it appears on the screen - let go of the buttons. Let the iPad start up.
2. If you lost sounds for keyboard clicks, games or other apps, email notifications and other notifications, system sounds may have been muted.
System sounds can be muted and controlled two different ways. The screen lock rotation can be controlled in the same manner as well.
Settings>General>Use Side Switch to: Mute System sounds. If this option is selected, the switch on the side of the iPad above the volume rocker will mute system sounds.
If you choose Lock Screen Rotation, then the switch locks the screen. If the screen is locked, you will see a lock icon in the upper right corner next to the battery indicator gauge.
If you have the side switch set to lock screen rotation then the system sound control is in the control center. Swipe up from the bottom of the screen to get to control center . Tap on the bell icon and system sounds will return.
If you have the side switch set to mute system sounds, then the screen lock can be accessed in the same manner as described above.
This support article from Apple explains how the side switch works.
http://support.apple.com/kb/HT4085
3. Try cleaning the dock connector opening of the iPad with a soft brush and just a little bit of rubbing alcohol.
4. Reset all settings. Settings>General>Reset>Reset All Settings.
Aug 12, 2014 | iHome Ipad/ipod/iphone Rechargeable Mini...
IPad has no sound even though volume turned up
Have u gone to your settings , Find sounds and try that !!
Dec 02, 2013 | Apple iPad Mini
How do I turn on sound on my new iPad?
Go to the side of the ipad and their should be a + and - sign, you press those to turn the volume up and down. if that doesnt work then you could go to settings then go to sound. Their you should see the sound icon which you can turn the voplume up and down!!
May 02, 2013 | Tablets & eReaders
Ipad 3,32gb.cant get on the net anymore?
Sounds like your in airplane mode. Go to settings , and turn it off
Jun 16, 2017 | Apple Tablets & eReaders
How do I turn off mute on my ipad
Try the switch next to volume controls, or try just raising the volume.
Jun 20, 2012 | Apple iPad 2 Wifi 16GB
Apple iPad 32 GB WiFi Tablet PC Logo
85 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
