Question about Tablets & eReaders
My ematic edan xl egs109 tablet is locked tried power button and up volume got a robot with red exclamation mark. will not give me options to choose factor reset
benjamin_951
  • 53 Answers
SOURCE: my tablet is not powering on..it is getting charge
Two most probable problems:
-bad battery
-bad motherboard
If it's still under warranty, get it repaired.
If not, buy a new one
Posted on Oct 13, 2013
  • 8064 Answers
SOURCE: I have a Tablet that was giving to me from a friend but she has forgotting her password and its lock at the main screen. I tried by pressing the reset button as well pressing the volume button but not
Take it back to the generous person who gave it to you and ask her to try hard to remember the password or to unlock it for you so that you can change the pattern. Or contact the manufacturer's service center.
Posted on Dec 06, 2013
monacolegend
  • 4 Answers
SOURCE: I am trying to factory reset my irulu AK 303
I am not familiar with your brand of tablet, but my Proscan 10" one has a reset button on the back. If you can find it listed in the owners manual or somewhere on the tablet, I would try that next.
Posted on Feb 08, 2014
mindreader
  • 578 Answers
SOURCE: I have a nobis Tablet.I tried to do a hard reset
guess is that the float level is not closing (need to open float bowl and clean everything inside with carb cleaner. Confirm that the float is operating (up and down) . Reassemble and try again...should be fine.
Posted on May 25, 2014
cougar123
  • 77 Answers
SOURCE: the 7 inch tablet when you turn it on shows the 2 dogs then goes to rca logo and nothing else. tried to reset by holding power & volume button at same time, did not work
contact vendor mfg - shoulds be under warranty
Posted on Jul 11, 2014
Ematic lp2p tablet doesn't recognize usb or pc
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
Apr 27, 2015 | Tablets & eReaders
How do I unlock my tablet
If it's android then you can reset it but you will lose all the apps you installed along with any saved passwords.
power off the tablet by holding down power until screen goes blank.
hold both the power button and the volume up button for at least ten seconds.it should boot to android logo...then a robot with red exclamation.leave it alone until the option to reset screen appears.
follow onscreen instructions to reset.
Jan 26, 2015 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Oct 29, 2014 | Tablets & eReaders
I bought the tablet off of face book yard sale and
hi there.
this is all i could find out from the internet so not sure if it will work for you.
I think it,s time for a factory reset , you will lost all you data !!!!!
or try this link out.
android man on his back with red triangle on his chest Google Search
Dec 15, 2017 | Tablets & eReaders
How to do a hard reset on an ematic 9" edan XL
check the back they my be a small holl or when the power buttom hold down for 3 should
May 16, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
Locked out of tablet
You could try to factory reset the tablet but that would delete everything you installed and downloaded unless you had everything backed up
Apr 02, 2014 | Ematic EDAN XL 9 inch Tablet with 8GB...
Just purchased Ematic EDAN XL. I let battery partially charge and continue to have connected to wall electrical outlet. The touchscreen is not responding. I have reset it and it continues to sit until it...
Try cleaning the touch-screen with a tissue or touch-screen cleaning paper, then wash your hands and use a skin moisturizer on your fingertips. If it still doesn't work, something's wrong with the unit. The touch-screen should work down to the discharge limit of the battery.
Note: when you buy a new lithium battery or device that uses one, it is a good idea to charge it completely before using. Some types of battery charge controllers use this first cycle to calibrate battery parameters so you get optimum performance from the battery.
Nov 11, 2017 | Ematic EDAN XL 9 inch Tablet with 8GB...
Forgot password
So all you have to do is power it down.
Press and hold + volume button and start the tablet.
It will give you 3 option . Select errase all data and factory reset.
Jan 08, 2014 | Ematic Tablets & eReaders
I have locked myself out of my tablet
You will need to do a factory reset:
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Oct 29, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Nexus 7 wont turn on
You can try to do a hard reset by holding down the power button and the volume down button for 20-30 seconds. IF the device still will not turn on make sure it has enough battery or is plugged in.
If you still have problems you can try the following to do a factory reset:
  1. If your tablet is on, power it off.
  2. Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power). You will see the word Start with an arrow drawn around it.
  3. Press Volume Down twice to designate Recovery mode.
  4. Press Power to restart into Recovery mode. You will see an image of an Android robot with a red exclamation mark.
  5. While holding down Power, press Volume Up.
  6. Use the volume keys to scroll to "wipe data/factory reset" and press Power to select it.
  7. Scroll down to "Yes - erase all user data" and press Power to select it.
Source: https://support.google.com/nexus/answer/2668187?hl=en
Hope that helps!
Sep 02, 2013 | Google Nexus 7
Tablets & eReaders Logo
49 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
