Question about Cooktops
How do I find instructions on how to replace a glass ceramic top top, Jenn Air # W10204669 on a 30in, Jenn Air gas cooktop with downdraft Mdl JGD8430ADB ? The instructions given by a previous post by
Searched the internet for hours.
Eddie Rentas
  • 59 Answers
SOURCE: replace glass top
Hello Bob
I have attached the link for you to request the manual for that stove....just go there and fill out the form and they will email you the manual in a few hours....I did the same thing and I got it the same day.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US
Eddie Rentas
Tupper Lake NY
Posted on Jul 19, 2008
aborcass
  • 2651 Answers
SOURCE: JENN AIR GLASS TOP REPLACEMENT
the glass top replacemnt is a pretty straightfoward task, a matter of unscrewing one and repalcing it wiht anew one. after ordering new top its a matter of lookin g at eh new top to see which screws would need to be removed from old. hardest part about job will be youll need to do disconnect the downdraft from the venting ,and pull unit up from the counter inwhich it is installe.< not difficult but cumbersome and awkward to manuver. check abd verify full model and serail number and cal manufacture for correct part umber. may cast anywhere fom 200-400 dollars depending on model
Posted on Nov 04, 2008
SOURCE: downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Posted on Nov 30, 2008
SOURCE: Jenn-Air Cooktop replacement needed
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
Posted on Apr 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: Need To Replace the Cooktop of my Jenn-Air downdraft
Here is a blowup diagram of the cooktop.
CLICK HERE
Looking up the service manual - it is no longer available.
Hope this is helpful.
Thanks for using FixYa!!
Posted on Apr 29, 2009
Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
Brandon@Stonerepairman.com
406.471.0000
Mar 25, 2011 | Jenn-Air 30 in. Expressions CCGX2420 Gas...
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
CLICK HERE
Apr 25, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Apr 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn air glasstop
As long as the pan bottom is truly flat, you sure can. Hope this helps!
Feb 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Replace JED8430ADB Ceramic Glass
First, you have to pull out the cooktop from the counter and remove the knobs.
Next, there are hex screws around the perimeter - do not remove the lowest ones on the front and the back (they hold the tray that the burners sit in) or the ones on the bottom (they help to hold on the blower assembly).
The final trick are two screws that are located in the downdraft plenum - there's one on each side (you don't have to remove the two in the back or the front - those are for small covers only).
The glass should lift out.
When putting the new glass in, remember that the plenum walls fit on the inside of the glass (you won't see the top of the steel).
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Nov 04, 2008 | Jenn-Air JED8430 Electric Cooktop
Downdraft vent on jenn air cooktop
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Cooktops Logo
67 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
