Everything the manual for my Zeepad Android 4.4 tablet says to try. I have three connections that say "excellent". The first one says "Security WPA2 PSK". Then it requests a password. I have no idea w
Everything the manual for my Zeepad Android 4.4 tablet says to try. I have three connections that say "excellent". The first one says "Security WPA2 PSK". Then it requests a password. I have no idea what the password is.
    New Friend:
  • 22 Answers
The password (code) should be printed on the bottom of the router.
Posted on Dec 12, 2014
marked
  • 6487 Answers
SOURCE: Problem with Lenovo IdeaPadS10e and D-Link DI-524
This problem is with the firmware of your router so the best thing to do to correct this is to update the firmware of the router and you can get it from Dlink web site...
Posted on Apr 23, 2009
anandg27
  • 1272 Answers
SOURCE: I can't connect to my wireless netgear wndr3300 to XP
It seems that the wireless adapter on XP does not support WPA2 Security. Please enable WPA-PSK on the router and check if you are able to connect to the wireless network on the XP computer.
ENABLE WPA SECURITY
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a Password in the passphrase box. Apply the settings.
Configure XP computer:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Posted on Sep 05, 2009
  • 742 Answers
SOURCE: Laptop can't connect to DSL-G604T
You need to configure your router and use WPA encryption so that all accessing device can connect to it.
The obvious reason why the dell laptop can't connect is because of the WPA encryption set. It is different compared with what your router is actually broadcasting: WPA2.
So you can choose one of the 2 things to alter. Change your router's WPA2 encryption to WPA or change your Dell's setup to WPA2.
Posted on Mar 05, 2010
SOURCE: Kindle 3rd Generation -- Linksys
I don't have a solution -- I'm having the exact same problem and I'm looking for a solution. Called Kindle tech support, and all they could recommend was to go to McDonald's to see if I can connect using their wireless. They DID say this Linksys WRT54G router is a compatible router with the 3rd Gen Kindle.
Posted on Jan 23, 2011
  • 26 Answers
SOURCE: My Atheros AR5007 will only
Since the connection works without the encryption settings, it is NOT a driver issue. It sounds like a missing wireless network security setup problem. So assuming Windows (Mac OSX is similiar):
  1. Connect a laptop/PC to the NetGear via ethernet. It saves on some aggravations later.
  2. Connect to the NetGear and restore the security settings, and remember your keyword.
  3. On your computer, open the list of Wireless Networks (usually Start->Control Panel->Network(ing)->Wireless Networks). The menu sequence might differ slightly, depending on which Windows you're running.
  4. Find and click on "Manage Wireless Networks" (or words to that effect)
  5. Right click on your wireless network's name to get the drop down menu, and select "Properties"
  6. Find a button or tab related to "Security"
  7. Under Security Type, select WPA2-PSK (or Personal)
  8. Under Encryption Type, select "AES"
  9. Under Password (or Security Key), type in your router's WiFi security key word. You may have to log back into the NetGear and find the keyword (yours) or the alternate (gibberish) form.
  10. Save the settings
  11. If you're connected to that wireless network, then disconnect
  12. Try connecting to the wireless network again. It should work this time.
Posted on Feb 23, 2011
My zeepad tablet wont connect to my WiFi
This may be a firmware problem. I had this problem. Download a android firmware app. Actually it's called android firmware and updates app and it's free. I don't think these cheaper tablets update as they should, that causes them to not connect to the internet. Why? I don't know. It drove me crazy. I tried everything. My daughter figured it out after messing with the tablet for months.
Mar 09, 2015 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
How do I setup the wi-fi Internet connection if I don't know the passwords?
You can probably find the password in the setup manual/instructions that came with your modem/router.
Hope this helps.
Dec 08, 2014 | Computers & Internet
I would like to download a user manual for my ZeePad 7.0 tablet
Hello there!
just try to download from this website! good luck!
http://www.dannon.biz/ebooks-operating/operating-instructions-for-zeepad-7.0/
May 27, 2014 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
IS THERE A MANUAL FOR A ZEEPAD 7 TABLET
Go to Settings -> Storage -> Factory Data Reset.
If that is not an option, then:
1. Power of the device completely.
2. Hold down both volumes and power at the same time. This should bring up an image of an android on its back, opened up.
3. Press both volumes at same time to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
5. Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
6. Your zeepad should now be reset
May 25, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
How can I reboot my Zeepad?
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
May 16, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
Zeepad still freezing i want to keep it, i just followed instructs in box, charged it, held power down for three minutes, and now recharging for two hrs. any tips, i don't like returning things i purc
Upon first use, you have to charge the battery overnight. Then for every recharge, you may have to keep it connected to the charger for at least 4 to 6 hours depending on your tablet, otherwise, your battery will go kaputt in a short period of time.
Mar 12, 2014 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
I am getting "Authentication Problem" with WiFi on 2 tablets - excellent signal. Accepts the security code and will hold for a minute or so.
I see three points:
1. check if the password of the router is the same you have signed in the wifi-account of your tablets - it's typical that a wrong password is prompted with no error message.
2. check if the wifi-protection of your router has the same type (WPA, WPA2) as your tablets use
3. check if the router accepts new wifi-devices, sometimes there is a checkbox "only known devices can access via wifi"
greetings, bernd-steffen
Oct 12, 2013 | Android Tablet PC
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
