My microtek inverter eb860 charging section complaint
3 Suggested Answers
  • 4088 Answers
SOURCE: i am using microtek 810.
If this is a 12 volt battery situation, 24.6 volts is not doing good things for your batteries--it will buckle the inner plates causing immediate battery failure. Were the fuses themselves blown or just the fuse mounts which may have been underrated. You definitely need a schematic for this system--try googling 'microtek 810'. Good luck!
Posted on Aug 15, 2010
SOURCE: Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Posted on Mar 09, 2011
Microtek inverter FAN NOT WARK
perhaps some oil on the bearings/bushings will help .
Aug 30, 2015 | Microtek Office Equipment & Supplies
Can i use 150 am 12 va battery with 2000va microtek inverter
You can use any size you want, just your UPS can charge the battery.
You can also add an extra charger in special cases.
If your UPS calculates backup time, you need to tell how big the UPS batteries that you have ...
Aug 19, 2014 | Computers & Internet
Microtek Inverter high output problem
Did you check the voltage under load, some power supplies float high when there is no load connected
Mar 01, 2014 | Electronics - Others
Hi, I have Microtek 810 Inverter, it is charging properly, problem starts when mains goes off and inverter is in Battery mode, then output of inverter shows no voltage, even i conected multimeter to...
Good day!
You have to do is:
Check the battery if it is leak.Use a voltmeter to test the output voltage of the battery.If your battery had a low supply voltage even you charge it for 3 hours and above.Replace the battery immediately.
Thank you and good luck.
Apr 21, 2011 | Vacuums
I am using microtek 810. Inverter section is ok. In the pcb there are two 40amp fuse which were blown off. suspected heavy current drainage. both fuses are in parallel and in the battery -ve line. i...
Aug 15, 2010 | Garden
MICROTEK INVERTER HELP
Bad batteries, replace all of them together.
Oct 02, 2009 | Electronics - Others
Jan 17, 2009 | Computers & Internet
jasbo
jasbo
