Question about Blodgett Ovens
Temperature I have electric Blodgett oven sometimes it get hots right away, sometime it takes long time to reach temperature. This problem started 4 days ago. Any suggestion?
SOURCE: Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
Posted on May 13, 2008
  • 139 Answers
SOURCE: Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
Posted on Aug 28, 2008
SOURCE: Oven only reaches temp of 220 degrees.
meter the electric-220 metering the positives...110 metering 1 positive & ground at a time...Ohm the element if shows open(10 dollar multimeter doesn't move) then is bad.Can be reached from the back just above where the power attaches,for safety disconect the power
Posted on Feb 13, 2009
aborcass
  • 2651 Answers
SOURCE: Ovens do not come up to set temperature
most common issue wsith these gas wall ovens is faulty ignitors, i would reccomnd replaing the ignitor(s). that being said i wouuld also reccomned a servicer with experience on this model for they can be a more tricky then ohter ranges out there, and the possiblity of "shorting out" adddiont al parts is higher on this model! and no one is currently producing a double self cleaning, full sized gas wall oven, so id hate to see you ruin this one!!!
Posted on Feb 16, 2009
heatman101
  • 43501 Answers
SOURCE: why does it take so long to preheat.
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 26, 2010
Temperature does not always reach set point of 425 F.
Oven will not hold correct temperature:------- This can be caused if temperature probe not working.Resistance across temperature probe leads at room temperature (70°F) should be approximately 1096 ohms.----------- Other possibility for this problem is :--- Temperature control not calling for heat.When heat is required, there should be continuity between terminals 6 and 7 on temperature control.-----------Inadequate or improper ventilation.Check ventilation hood. Verify draw and make up air adjustment.-----------If all this checked out ok then its calibration problem.For calibration follow this procedure:--
It can be problem with temperature controller. TEMPERATURE CONTROLLER (Standard-Control Models Only) The calibration of the temperature controller should not be changed until sufficient experience with cooking results has definitely proved that the temperature controller is not maintaining proper oven temperatures. Before any recalibration is attempted, the oven temperature should be checked by the following procedure: 1. Remove all trays and pans from the oven. 2. Place a thermocouple or a reliable mercury oven-type thermometer at the center of the middle rack. 3. Turn the oven ON and set the temperature control knob to 400°F. 4. The amber "heat on" light will go out when the oven temperature is reached. 5. Allow three cycles for the temperature to stabilize. 6. Read the thermocouple or thermometer immediately after the light goes out for the third time, and again immediately after it comes on the next time. 7. If the average of these readings varies by more than 10°F from the dial setting, recalibrate by the following procedure. Recalibration should be attempted only by a competent service technician. Use the following procedure to recalibrate the oven: 1. Loosen the two set screws that secure the temperature-control knob to the temperature-control shaft. 2. Remove the knob from the shaft, being careful not to rotate the knob or shaft. 3. Replace the knob on the shaft so that the indicator mark on the knob points directly at the temperature that was measured at the center of the oven. 4. Re-check the oven calibration. ----------- Part number for temperature probe is 1181996 and you can order if from the Southbend service center. -------- If you want the manual and wiring diagram for your oven.Please click the link directly:-- http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man ----------- after you click the link,a page will open in that you fill the 5 letter number.And click the "download now " option.It will ask you to save or discard.Click the save option and download will start.It will take 2 mins to download.Then click the download file to open it.And go through the manual.------------This will help.Thanks.Helpmech.
Jan 28, 2011 | Southbend ES10SC Electric Single Oven
Oven will not reach the required temperature
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 09, 2011 | AEG D5701-4 Electric Double Oven
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
CTB temperature adjustment knob shaft
The blodgett part number you are looking for is 18234 Potentiometer remote (infinite control) I dont know if you are able to buy directly from blodgett here is the number for blodgett 1-800-331-5842 the blodgett web address is blodgett.com if you are not able to order from blodgett you might try another company generalparts the number for general parts is 1-816-421-5400 kansas city location. the web address for general parts is generalparts.com
May 13, 2008 | Blodgett CTB BASE Electric Single Oven
Ovens Logo
55 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
butch welch
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
