Question about Brother LS2350 20-Stitch Functions Sewing Machine 22025146
Problems with sewing, the thread keeps getting knotted up I the bottem. The spool of thread that is on the top is wrapping around the stick when trying to sew?
Changing thread, re thread bobbin several times, oiled it,
  • Brother Master
  • 1,860 Answers
Also make sure the bobbin is inserted into the bobbin case correctly, counter-clockwise
also make sure the top thread is correct, use every thread guide
Posted on Dec 08, 2014
  • 3 Answers
Try changing the needle if that doesn't work try adjusting the foot pressure. I had that problem with one of my quilts and It was the presser foot. I used google to find a lot of answers for machine problems, You would be suprised how many answers and utube videos you will find to show you how to fix things.
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Sep 05, 2016 | Kenmore Sewing Machines
I have a Quantum CXL Singer sewing machine and the thread keeps breaking. It will make about 3 stitches and breaks. It is breaking in the same place.
Make sure the thread coming off the spool is not wrapping around the spool spindle. Install a brand new needle. Remove ALL the thread from the machine. Clean bobbin area of any dust, lint, threads. Set upper tension to the midpoint. RAISE the presser foot and then totally re-thread the machine from beginning to end verifying the sequence is correct. Test.
Why Does My Sewing Machine Top Thread Keep Breaking Howcast
Oct 06, 2015 | Singer Sewing Machines
Singer sewingmachine how to stop thread from breaking on the top
Thread breakage is often caused by a burr on the needle. Whenever i have a problem with thread breakage, I unthread the machine, replace the needle, and rethread.
Sometimes thread will wrap around the spool pin, so I use the upright spool pin or use a mug or water glass to hold the spool upright behind the machine.
Jul 19, 2014 | Singer Sewing Machines
Need to put bobin in a merritt 4530
Flip the presser switch up to raise the presser foot. Turn the hand wheel counterclockwise until the needle is in its highest position.
  • 2Hold the hand wheel in place with your left hand while turning the hand wheel knob counterclockwise with your right hand to loosen the hand wheel knob.
  • 3Place the desired spool of thread on the spool pin so that the pin fits all the way through the hole in the center of the spool. Put the spool holder onto the end of the spool pin that is sticking through the spool of thread and press firmly to ensure that the spool holder keeps the spool in place.
  • 4Grasp the end of the thread and hold it taut between the thumb and index fingers of both hands. Snap the taut section of thread into the thread guide post located to the left of the spool pin.
  • 5Pull the end of the thread gently. Wrap the thread around the bobbin winder tension disk near the left front on top of the machine, starting at the side of the tension disk facing you and wrapping around in a clockwise direction.
  • 6Poke the end of the thread through the small hole in the bobbin from the inside out so that the loose end of the thread sticks through the top of the bobbin. Put the bobbin on the spindle, or bobbin winder, and gently slide the bobbin winder to the right.
  • 7Hold the loose end of the thread in place while pressing down on the foot pedal to start the machine. Hold the foot pedal down until the bobbin is as full as desired. The machine will automatically stop once the bobbin has reached capacity.
  • 8Cut the loose end of the thread using scissors. Slide the bobbin winder to the left and remove the bobbin. Hold the hand wheel in your left hand and tighten the hand wheel knob with your right hand by turning it clockwise
  • Apr 05, 2012 | Singer 6510 Sewing Machine
    Hello, I have a Shark euro-pro sewing machine. I am sewing denim on denim using singer needles that were suggested for denim. The numbers on the package are 2020 110/18 808 R 130/705H 05 un I...
    The size of needle is fine for sewing on denim so unless the needle is bent (and even so) I doubt that is the problem. Breaking upper thread typically has more to do with the threading, ie wrapped around some place along the way or misthreaded somehow, of even if you somehow got knots or that it has somehow got thread around the spindle for the spool. So first recheck the threading. Best to do by simply totally unthreading it, looking closely at the spool and winding and then rethreading it again. Make sure your upper tension hasn't been accidentally tightened too.
    Next check the bobbin and bobbin thread. First pull on the thread. Is it pulling real tightly or does it flow out readily? Take the bobbin out and look at it. Check the tension also. Is it too tight? That too can cause the upper thread to break.
    Is the needle penitrating the material smoothly? Again examine the needle closely to see if it's developed a burr. Better yet just swap the needle with a new needle and try it.
    The majority of the time it is one of these things that will cause the top thread to break.
    May 18, 2011 | Euro-Pro Shark 80 - 7133
    Bobbon thread is too losse /thread breaks no
    Clean out the bobbin area.
    Thread the machine with the presser foot up. This opens the tension so the thread can enter. Threading with the foot down closes the tension and the thread cannot enter as it should. When you sew, the top thread is loose and cannot properly connect with the bobbin thread to form a tight stitch. The stitching does not hold and pulls right out.
    Thread breakage - top thread? Check the thread spool to be sure there aren't any nicks to catch the thread.
    When the thread breaks, check the spool pin to see if the thread is unwinding too fast and wrapping around the pin. Thread nets can help stop this. You can find them at sewing machine dealers.
    Mar 11, 2010 | Singer Sewing Machines
    Bobbin continues to pose problem - knotting thread underside of fabric,
    In 99% of all problems with "bird's nesting" or "knotting" it is an issue of the thread coming out of the take up lever (at threading guide #3) (from the spool; through the first thread guide at #1 down to #2 and up to # 3) when the thread comes out of the take up lever, the machine can not regulate the thread and it floods the machien with thread and wraps itself around the bobbin case. OR! Your tension is too loose. Raise it. Your machine should preform perfect at tension #4 unless you are using speciality threads or fabrics.
    ALWAYS be in the habit of threading your machine with presser foot up so that while threading between paths 1 and 2 you are certain to have the thread pass throught the tension disks.
    This will happen on a $50.00 machine or a $5,000 machine. The thread needs to be regulated.
    USE GOOD THREAD!
    Thanks,
    Bonnie
    Oct 25, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
    Thread constantly wraps around spool pin
    Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
    Hope this works.
    Zelma
    Jan 19, 2008 | Brother LS-2125 Mechanical Sewing Machine
    Brother LS2350 20-Stitch Functions Sewing Machine 22025146 Logo
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
