Question about Hardware & Accessories
Any chance you have the "how to operate/program" instructions for the C (outdoor)?
We replaced the battery for our Intermatic Rain Tight Outdoor 7 day digital timer MODEL HB71R70 but the instructions to reset the timer have been misplaced. Could you please supply us with step by step...
Hi Maggie.
Intermatic no longer makes HB71 timer, and I cannot find instructions for the timer.
Intermatic website is offline on weekends starting March 2011, but I have searched the site numerous times over past year and they do not post that manual.
However I might be able to piece together steps if you add a comment and include in-focus photo of timer and buttons. Also include anything you can remember about setting the timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
My understanding so far is that this timer has 2 slide buttons, and several push buttons.
Typically slide button timers require both slide buttons to be in one position for setting timer, and another position for programming timer, and another position for operating timer. The complicated steps are why timer has been replaced with newer models with sleeker programming.
If you do not want to bother sending photograph, or working on the problem, then buy another outdoor timer for 20$
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
http://www.homedepot.com/Electrical-Dimmers-Switches-Timers/h_d1/N-5yc1vZ1xg8Zbm2d/R-100685861/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Apr 23, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I would like to have the instructions for operation of the Timer.
You posted under Woods 59403 timer
If you have different Woods timer, look at images at link below to identify timer.
Add a comment at any time
59403 timer manual:
http://waterheatertimer.org/pdf/Woods-59403.pdf
59403 programming Instructions:
Plug timer into indoor or outdoor wall outlet.
Plug lights into timer.
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
Press Hour button until selected hour displays for event1 ON
Press Min button until selected minute displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Press Hour button until selected hour displays for event1 OFF
Press Min button until selected minute displays for event1 OFF
Press PROG button until 2 ON displays
This is Event2 ON
Repeat steps above to set up to seven events.
Recommended you make chart of your on-off times before starting to avoid conflicts in programming.
When programming is finished, press MODE button until automatic displays.
To override programming, press MODE button until lights come on.
For random operation, press MODE button until RDM displays
Dec 02, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
I need to find instructions for my westinghouse timer model 28499 directions
Hello I made a couple of videos showing how to first set the time and day and then how to program this Westinghouse model 28499 3 outlet photocell timer.
Nov 30, 2010 | Heavy Duty Westinghouse 3-Outlet Outdoor ...
Noma Timer Model #ET525C - Require Instructions
ET525C is UPM timer
http://waterheatertimer.org/UPM-timers-and-manuals.html
UPM ET525C Manual
http://waterheatertimer.org/pdf/UPM-ET525C-heavy-duty.pdf
Instructions are 14 pages. It is impractical to re-write 14 pages of instructions.
If you have a problem, add a comment and say exactly which programming you want to set, and I will respond.
-Timer can be programmed for ON and OFF times, for Dawn-Dusk, for Countdown, for Daylight countdown, for daylight saving, and for Random. Each different programming option has 8-12 steps shown in manual.
Nov 28, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Need directions on how to program this outdoor timer, I lost the original instructions
Is this a vacuum system? If this is an outdoor timer for a Central Vacuum system, there will not be an outdoor timer, nor an indoor timer. If you are operating a ROBOT vacuum, there is a timer on the charger. Please explain.
Nov 16, 2010 | Vacuums
Hardware & Accessories Logo
43 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
