The machine would not stop adding water.
Nothing so far. Researching
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 242 Answers
Something to do with the pressure sensor is broken, it cannot tell that is has reached full level. there could be a break or block in the pipe that goes to this sensor. the pressure sensor itself could be faulty and need replacing.
Posted on Dec 08, 2014
Starts normally, fills with water, after two turns drains
check your cycle time by adding more minutes and see what it does.
Mar 14, 2014 | General Electric WBVH5300KW Washer
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine stops in the middle of the cycle. I had only a robe and pair of pajamas in the tub and water level set at medium. I moved it to "spin cycle" to get the water out of clothes, but nothing...
Same problem as yours. The GE repair man is at our house right now for this problem. It's the motor, and the "special motor and clutch package" has to be specially ordered.
Jan 04, 2011 | GE Profile WPRE8100G
After first wash cycle, machine beeps and we get a
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Aug 01, 2010 | Kenmore 44921 Front Load Washer
Washing machine loud bang, now no water
you could have a broken or clogged bump,as far as the latch not opening it could be slightly off line
Nov 05, 2009 | Washing Machines
Extremely loud squealing noise during steaming milk
This could be blocked. The best way to clear this is to switch off the machine and see if you can dismantle the frother arm. Sometimes the arm will come off by unscrewing. If it does, wash it in hot water and washing liquid. If it doesn't come off try putting the frother wand into a mug of cold water and allow it just to steam the water.
Frother wands don't just steam liquids - they **** up liquid which can block the vents and the actual steam hole which this machines' problem sounds like it does have.
Apr 05, 2009 | Breville ESP8XL Espresso Machine
Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Nead help pleace
When it says to ventilate, it is asking you to prime the pump. Put a cup under the panarello wand ( the steamer/frother) to catch the discharged water and press the hot water button (upper left button on my machine). Wait until air stops coming out with the water, usually 3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 15, 2009 | Saeco Royal Digital Plus Coffee...
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
Top Washing Machines Experts
