Question about Dimplex Heating & Cooling
How do i wire dimplex quantum
One power supply
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
Dimplex PW4 timer not working with heaters
In UK, you can call 0845 600 5111
The manual is very unclear about:
1) Wiring.
2) Resetting the timer when encountering a problem due to surge, power outage, or malfunction.
3) Troubleshoot section is missing.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
Jul 25, 2012 | Dimplex Epx1250 Panel Heater
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Mar 03, 2010 | Heating & Cooling
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Dec 19, 2009 | Dimplex Heating & Cooling
Please help me to get the manual. dimplex thermostat, or i need help to stall my thremostat
Dimplex products are typically sold at most Home Depot and professional electrical supply houses. However, they rarely will have all the literature for those products in their stores.
Dimplex once provided an online list for all their heaters and thermostats, but no longer have the product manuals available on their website for customer download. They make both 120V-AC and 240V-AC versions and several different models, so I can't safely provide you with the wiring connections, since each installation is different and depends on the type of thermostat and heater(s) being utilized.
So now that I've given you the bad news, let's move onto the good news!Dimplex now uses an online request form for customers to get manual and literature on all their products. They'll send you the manual for your Dimplex product free, once you submint the request.
Here's the link to the request form for you to fill out and submit, just have your model number handy and you should be all set.
http://www1.dimplex.com/customersupport.aspx
Hope you find this Very Helpful and best regards!
Sep 18, 2009 | Dimplex Heating & Cooling
The heater on my dimplex fire appears to be working however i replaced dud bulbs with new bulbs, and they are not working?
dear sir/madam
have you checked for the power supply before changing the bulbs,if not please check it then you come back to us we will help you.
Aug 06, 2009 | Dimplex DS5598 Mid-Size Heater
Cable/Transformer for Quantum Server 1000
I've got the same Snap Server 1000 and lost the supply some time ago - I found a LiteOn monitor supply model PA-1400-02 does the trick and fits exactly.
Spec is 3.33A 12Volts DC out, positive inner, negative outer.
Hope that helps.
Jan 19, 2009 | Quantum Snap Server 1000 (5325301081) 10...
Heating & Cooling Logo
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
