Question about Sony Bravia KDL-37M4000 37 in. LCD HDTV
Any time I use number 3 my Sony Bravia looses picture &sound What can I do? help?
    Top Expert:
  • Sony Master
  • 75,591 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 08, 2014
HDTV GURU
  • 261 Answers
SOURCE: sony bravia
It sounds like the backlight is going bad or possibly the panel. Let me see a picture of it. Talk to you later. Jay
Posted on Feb 01, 2008
jomabug76
  • 1148 Answers
SOURCE: unable to turn sound on, picture is fine. volume numbers increases but still no audio
check menu make sure ,,internal speakers are on,,check rca jacks
Posted on May 15, 2009
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
welcomejee
  • 10594 Answers
SOURCE: No picture or sound. Red light
Just a correction, it is not necessary that 4 times red light blinking always shows inverter board problem.
It depends on chassis/ model number of Sony bravia tv to what is error code of 4 blinks as it would be mentioned service manual.
I'm Sony tech and can help you, let me know model number written at back of tv to provide you exact info about 4 times red light blinking.
Thanks.
Posted on Aug 18, 2010
What is an LD board/ LDHM board?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Dec 22, 2016 | Sony Televison & Video
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Why does my tv stop.when I use number 3 my Sony Bravia looses picture &sound
Contact the authorized service center for Sony. It sounds like corrupted firmware. Electro help
Dec 08, 2014 | Sony BRAVIA Televison & Video
Sony Bravia KDL46W4150 crackles and volume suddenly increases
Hello
There is some loose solderings or leaky ceramic capacitors at the audio output section of your sound card. Check it.
Feb 28, 2012 | Sony BRAVIA KDL52XBR2 Television
Sony Tv Bravia won't switch on for days, when on only white light and sound no pictures. Help
I think fault is in electrolyte capacitor.You should check the supply volt of cathode & all relative component of RGB input.
Jan 12, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No picture or sound. Red light blinking four times on sony bravia tv. Suspect power supply problem?
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv. As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from www.partstore.com ----------- Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 18, 2010 | Sony Televison & Video
My sony bravia has sound but no picture error code blinks 5 times
Repair unfortunatly. Any blinking LED should be checked over by a repair agent.
Call Sony direct on 0845 6000 124 local rate number to book it in.
Good luck
Nov 07, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sound turns off after tv is started sound only one
Hi my name is Roety,
I can help you with your issue ,
Without a model number, I do work on sony LCDs.
The audio is on the mainboard. You need the mainboard replaced.
Reboot every device by unplugging the AC power , if the sound still cuts off replace the mainboard
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 10, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-37M4000 37 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
