Question about Amana Microwave Ovens
Why will the door not lock and stay closed ?
It will run if I hold the door closed tightly.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 173 Answers
Ithink the door clips spring is loose inside so openthedoor cover orjust move your door clips by hand it must not be too loose
Posted on Dec 10, 2014
  • 3 Answers
SOURCE: Microwave Problems
I just had this issue happen to me last week.. fortunately I was standing in my kitchen when it happened... I heard a snap and then a piece fall down the inside of either the door or the front key panel.. I'm assuming this controlled the door locking/oven turning on safety mechanism. The inside light wont go off and it won't turn on to cook.. I am trying to figure out if it's worth paying to fix or just replace the whole unit!? Anyone know if this is fixable by oneself rather than spend a bunch of money on a service technician??
Posted on Mar 03, 2011
  • 3 Answers
SOURCE: Door won't stay closed
MicrowaveSvc
  • 9098 Answers
SOURCE: My microwave no longer starts when the door is
On the DMT2420, that's a bad bottom door switch, or possibly that switch's mount.
The service manual is here and the parts list is here. You can order Dacor parts by part number from the Pros here.
Posted on Nov 21, 2011
  • 6771 Answers
SOURCE: Does not heat food-master relay reset, all electric OK (fan runs, time & all other settings show OK, turntable rotates), door closed tightly, control lock
THere are three possibilities, open magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor.
Posted on Mar 15, 2012
ercupa190
  • 12223 Answers
SOURCE: microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Posted on Jul 20, 2012
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
Microwave door wont stay closed
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
Mar 22, 2012 | Electrolux ICON Microwave Combination Oven
Mar 14, 2012 | Maytag MMV1164WB Microwave Oven
My microwave no longer starts when the door is closed. You have to hold the door tight for it to work. Door is not shutting tightly enough.
Feb 11, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Problems
Jul 28, 2010 | Sharp R-1610 Microwave Oven
May 28, 2010 | Sharp R-1610 Microwave Oven
Oven keeps shutting off, says close door or says push start. When you push start again or restart only runs for few seconds and then shuts off again
1)Make sure there is a clearance all round the machine so that there is a good airflow. The sensor is picking up a lack of circulation or heat factor.
2) Chdeck the door switch, it may well not be closing correctly. when the door is closed and prior to hitting start,\; pull the door gently to see how much movement or play is in it. The door should be tight and have almost zero movement. Look at t both sides of the door lock to ensure no debris is preventing it from closing correctly, and the latch itselof is not broken!
Thanks for using FIXYA
Oct 13, 2009 | Microwave Ovens
Microwave Ovens Logo
70 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
foster_mommy
Level 1 Expert
Jim Thurston
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
