Question about Samsung Washing Machines
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
I tried using different wash cycle like: fuzzy, blanket to see if it is the water would turn off after it is full and the rinsing has started. But the water keep running. I have to stop the machine and change cycle to spin so as to drain the tub. Please HELP!!!!!!
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 224 Answers
This could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Posted on Dec 08, 2014
JULIANFIX
  • 975 Answers
SOURCE: Miele rinse light keeps flashing
did you check the DRAIN PUMP MOTOR ? IT COULD BE CLOGGED or something blocking the impellers
Posted on Apr 19, 2008
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
  • 188 Answers
SOURCE: Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Posted on Feb 19, 2009
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Lg fuzzy logic washing machine
Sounds like it's stuck in rinse, try unplugging it for 5 mins then power up turn the selector to normal cycle and start, see what happens. There might be a reset cycle it has to do. Or a programming mode. LG 18002430000 customer service
May 15, 2014 | Washing Machines
My front load washer had a f09 then e01 code come up today. I think something is clogging somewhere
blankets can be very heavy and ball up on one side of the washer during spin cycle and cause the washer to shut down do to inballance... remove blankets & spread them ou if the are twisted up also mabe leave one of them out and rinse separatly..
Jul 09, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Jun 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Washing Machines Logo
182 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
