Question about Samsung Dryers
I'm not getting full voltage to the heating coil. It looks like Im getting voltage from the side that runs through the heater relay on the circuit board. The other side that runs through the motor h
I'm not getting full voltage to the heating coil. It looks like Im getting voltage from the side that runs through the heater relay on the circuit board. The other side that runs through the motor has a centrifugal switch. How does this sw work and how do you replace or check it? Shows on the wiring diagram but not sure if it part of the motor or not. I don't believe it is the belt tension switch, because the wires to that sw come from the circuit board. It is a Samsung Dryer DVA331AEW/XAA
    Genius:
  • Samsung Master
  • 1,342 Answers
Before getting to involved have you actually checked the electrical braker and circuit?
Posted on Dec 09, 2014
iwillfixforu
  • 619 Answers
SOURCE: the dryier runs but stop heating
Check the red wire coming in from the timer to the motor switch to see if you have power there. If you have power going into the motor but not out to the heater you need a new motor.
Posted on Jan 29, 2010
jsrock516
  • 5911 Answers
SOURCE: Dryer takes too long to heat
Okay...I'm not familiar with the configuration of Fisher and Paykel dryers. I am familiar with many other dryers, though. If the wires become melted this is usually caused by excessive current flow or a loose connection. When wires at a terminal become loose the intermittent connection can cause arcing which leads to the generation of heat, which causes the wire or connector to burn open. I have also seen heating elements short out against the casing and cause an excessive current flow problem.
Just so we're clear here, current is the force that causes electrons to flow. It is usually measured in amperes (or amps). What you are measuring is the voltage. Voltage is the difference in potential between two points. If you were to measure voltage between two points (such as through a simple wire coil) you would read 0 volts because there is no differnce in potential between the two points, as the coil should read a short. Now, if you have a RESISTIVE coil, or a coil that is open (broken) the same measure would yield a voltage reading, because there is now a difference in potential between the two points. Does this make sense to you? I know it can be confusing at times because you normally associate a voltage reading as something being good. In a nutshell: if you measure across a wire coil and read voltage - the coil is open. If you read 0 volts - the coil is good.
Who knows what caused the melted wire in your appliance. The one thing I am sure of is this is not normal. If you want to replace the relay to be sure, that is your judgement call. Relays do go bad. I would strongly recommend replacing the heating element as it appears that this model has a dual element that will still work (to some degree) if one side fails. Very ingenious design, by the way.
In addition, a lot of heat related problems associated with dryers are attributed to poor ventilation. A dryer requires proper air flow in order to work efficiently. If you have not cleaned or inspected your dryer vent ducting recently (or ever), you may want to. This is the source of many dryer malfunctions and can create a fire hazard or habitat for rodents. The rule of thumb when it comes to ventialtion is: The SHORTER and STRAIGHTER the ventilation, the BETTER. Every bend or rise you put in a dryer exhaust vent line creates resistance against the blower motor and possible choke points for lint to accumulate. The lint screens in dryers are not perfect and they do not collect ALL the lint. Simply cleaning the lint trap in many cases is not enough. Cleaning after every use, however, does cut down on the potential for your ducting to become clogged. If a dryer is allowed to run in a condition where it has poor air flow, the heating circuits will actually overheat to the point of failure. I mention all of this because I don't want you to replace parts only to have the appliance fail again due to poor ventilation.
I hope you find some of this information helpful. Let em know if you have any further questions.
Posted on Sep 12, 2008
  • 14 Answers
SOURCE: Hotpoint dryer nvl333eyoww, Motor runs, heating
Did you ohm out the thermal overload?
Posted on May 18, 2009
  • 523 Answers
SOURCE: Kenmore Dryer - No Heat
110 comes from the motor 110 comes from the timer remove the wire that comes from the motor see if you have 110 if you do the timer is bad if not the motor is. even if the motor is turning its bad
Posted on Jun 08, 2010
localwonder
  • 6784 Answers
SOURCE: Samsung dryer Mod DV328AEW/XAA electric 220v
HI. Ok, this unit is equipped with four thermostats that monitor the cycling information and the heater box for optimal operations. All of the thermostats should be tested for proper functions. I suspect that the culprit will be the thermostats mounted on the heater box, but test all to isolate.
Here are all the thermostats that are to be tested, below:
1. Thermal fuse - This will be mounted on the side of the heater box(chamber). Test properly to confirm its functions.
2. Cycling Thermostat - This will be mounted on the blower housing.
3. Cycling thermostat(2) - mounted on the blower housing
4. Hi-limit thermostat - Mounted next to the thermal fuse on the heater chamber/box.
Concerning the element:
You cant always tell by looking. This device must be tested to confirm that it is indeed working as designed. It should show some signs of continuity if it is indeed functioning.
Proper testing technique for most thermostats and fuses:
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Posted on Jul 30, 2010
Gecko blown heater fuse
check recirculation pump and heater element and temp sensor and pressure switch
Mar 10, 2018 | Pool & Spa
1991 Dodge Dakota 2.5 liter 4 cyc blew fuse I replaced fuse no start have replaced pick up coil ,coil,plugs ,wires, cap,rotor,fues all good still no spark and no start helllppppp please!!!!!
Make sure battery has a full charge. Did you check primary voltage to ignition coil, engine cranking, dark green wire with orange tracer? Use a test light, is it hot? The voltage comes from asd relay, check voltage and ground circuits. The load side of relay is that line with arrowhead, that circuit is fuse protected and hot all the time. The control side of relay is the left side in diagram, has to have voltage and ground. The voltage appears to come from ignition switch on or cranking. Grounded by computer.
The distributor has a sensor in it that sends rpm signal to computer, w/o that signal the computer won't ground the asd relay and you get nothing. The asd relay sends voltage to several systems. Just my opinion. Any applicable trouble codes?
May 29, 2017 | Dodge Cars & Trucks
Power windows and audio not working
This for power windows. The diagram should be enough to get you started on diagnostics. Check fuses and circuit breaker, also check for voltage on those circuits, use a test light to check for voltage. The accessory relay has to be energized. If you have voltage at load side of relay, you can bypass relay, with relay unplugged, use proper size jumper wire between terminals 30 and 87, the power windows should work. If so, the problem should be on the control/coil side of relay, voltage and ground, as you can see the instrument cluster grounds the coil side of relay.
I haven't looked at your audio yet?
Nov 30, 2016 | 2004 Ford Explorer
I have a 99 s-10. I'm getting the signal from ignition to the relay. But my fuel pump doesn't run nor does truck turn over.
There are two voltage circuits at the relay, one is the ecm B fuse, did you check that ? There are two side of the relay, the load side, see the arm with arrowhead, when relay is energized, that arm moves to other terminal carries voltage to pump motor on gray wire.
The control side of relay is the coil looking sign in the diagram, gets voltage from pcm, the black wire is chassis ground. Just to add, I looked at 6 cylinder.
Nov 06, 2016 | 1999 Chevrolet S-10 Pickup
Engine cold. Start engine reading says engine hot ac off. Fans run all time.
Are the fans running on low or high ?
Circuit/System Description
The engine control module (ECM) commands the fans ON in either high speed or low speed, depending on cooling requirements. In low speed, both fans are turned ON at a reduced speed. High speed has both fans turned ON at full speed.
In low speed operation, the ECM applies ground to the coil side of the fan low relay. This energizes the coil and applies voltage directly to the left cooling fan through the switch side of the fan low relay, which is fed by the fan 1 fuse. The right fan is connected in series to the left fan through the de-energized fan control relay so that both operate at low speed.
In high speed operation, the ECM applies a ground to the coil side of the fan low relay, the fan control relay , and the fan high relay. On the fan high relay, the energized coil closes the switch side of the relay and applies voltage directly to the right cooling fan through the switch side of the relay, which is fed by the fan 2 fuse. At the same time, the ECM energizes fan control relay pulling the switch side over, providing a direct path to ground for the left cooling fan, which has voltage applied through the energized fan low relay. In high speed mode, the fans are operated as a parallel circuit with full voltage applied to each.
You should have it hooked up to a scan tool that can read engine sensor data parameters . Check for DTC'S - diagnostic trouble codes etc...
Circuit/System Verification
  1. If DTCs P0480 or P0481 are set, perform those diagnostics first.
  2. Ignition ON, verify with a scan tool that the control module is not commanding fan activation.
  3. Ignition ON, observe that the fans are not activated.
Your best bet is to take it to a ASE certified repair shop !
Jan 10, 2016 | 2009 Chevrolet Silverado 1500
Looking for trouble shooting help with 2002 fuel pump under turbo chevy 3500 4x4 crew cab pickup. Relay doesn't seem to be getting signal to it from (?).i put voltmeter on coil side of relay and turn...
Did you do it like this? Voltmeter: black lead on negative battery terminal, positive lead on one of terminals on coil side- turn key to on, and see if there is voltage for about 2 seconds. If yes, check negative terminal of relay's coil side. If no voltage, move positive lead to other terminal for coil side. Turn key to on, and see if you have voltage for about 2 seconds. If yes, test negative side of relay's coil for good ground. If no signal at either terminal, the signal may be lost from the pcm.
When you turn the key to on, this will prime the fuel system-pump will turn on for only 2 seconds with key in on, and then if no crank signal, pump will turn off (the relay will not stay energized, so no power will go to pump). But when the engine is cranking over, the relay is energized, the coil side will stay powered as long as engine is cranking. After the engine is running, usually an oil pressure switch is tied into the fuel pump circuit, so the relay is no longer needed to put power to the pump. The pump will always be running when engine is cranking, and when engine is running, but the relay no longer is needed when engine is running. See?
Jan 24, 2018 | 2002 Chevrolet Silverado 3500
Dayton heater mod 2yu59 is not heating up?
Need to check the low voltage circuit for 24 volts, the 480 volt to 24 volt transformer may have a circuit protection reset or fuse installed. All the 3 phase electric heaters use a low voltage control circuit for operation of relays (24 volt coils).
Nov 22, 2011 | Dayton 2YU59 Electric Heater
Po540 code
DTC P0540: Intake Air Heater - Incorrect Voltage
The Engine Control Module (ECM) uses an Intake Air Heater (IAH) to warm the incoming air for proper cylinder combustion. The ECM grounds the control coil of the IAH relay to energize the heater during cold weather operation. If the ECM detects voltage on the IAH circuit when the relay is commanded OFF, or incorrect voltage when the relay is commanded ON, this DTC will set.
There are several possible causes for this code including:
Faulty IAH Relay
Faulty IAH Relay Control Circuit
Faulty Line Voltage Reference Circuit
Faulty Heating Element
Faulty ECM
Feb 28, 2011 | 2003 Chevrolet Silverado 2500HD
Blower fan stays running. Fan relay attached to small circuit board (coil tabs [timer?]). Capacitor on small circuit board had ''fallen out'' of ic board. Tried to get replacement board, and was sold...
If fan runs on 220 you have one constant 110 that always goes to the motor. The other 110 goes through something that will turn it off and on. This being the relay, just like a light switch. This 110 will land on the "N O" (normally open) set of contacts. "Open" meaning the voltage can't pass through. When the relay gets energized the contacts close. This completes the circuit, the motor gets the 220 it needs and it runs. On the relay coil (how it gets it's energy) you need a low voltage common and you need the "G" wire from the tstat. Likely green in color, this is your indoor blower low voltage wire. When the tstat calls for fan, cool or heat, the relay energizes, closes the contacts, fan runs. Good Luck!!
May 16, 2017 | Carrier Heating & Cooling
Dryers Logo
99 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
