Question about Dyson Vacuums
Can't get the Dyson 24 to switch from flat floor to carpet mode. What should I do?
My vacuum won't switch from flat floor to carpet
  • Official Brand Answer
  • 2,572 Answers
Hi Lee, it's Jack at Dyson.
DC24's cleaner head is engineered to adjust automatically when you move from one floor surface to another - there are no fiddly height adjustment dials or levers to adjust. When cleaning hard floors or delicate rugs, you can also use the silver brush control switch (next to the red on/off switch) to turn off the brush bar:
can't get the Dyson 24 to switch from flat - amp-39-t-get-dyson-24-switch-from-flat-m43difmpidfjgfho0k5c5fgh-1-0.jpg
If the brush bar doesn't seem to rotate at all, you may need to reset your machine as shown in the video below. You may find it helps to press the red reset button with something like the eraser-end of a pencil. You should hear and feel a click as it engages:
If you find you still need further help after giving this a try, you're welcome to contact our experts directly for some troubleshooting advice. If a repair or replacement part is needed, we can also confirm if this is covered under your Dyson warranty. Just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on Dec 08, 2014
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/
Posted on Jul 05, 2008
SOURCE: Dyson won't go back into upright position to engage suction
The dyson.com website had a solution for this particular problem. Just press in a button in the area around the right wheel while lifting the rear of the vacuum up. This allows the base to roll forward enough to go back into the upright position. I did this and it worked. All fixed.
Posted on Jul 09, 2008
b0sslady2001
  • 357 Answers
SOURCE: Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
http://cgi.ebay.com/DYSON-VACUUM-DC07-DC14-DC-07-14-BRUSH-ROLL-BEATER-BAR_W0QQitemZ120452265897QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b83b7a9&_trksid=p4634.c0.m14
Marci
Posted on Aug 07, 2009
Dysonteam
  • 167 Answers
SOURCE: Dyson upright, no suction at bottom in carpet or
Hi its Darran at Dyson.
It sounds as though the machine is blocked. with the machine switched off, check the base of the machnie by removing the soleplate and clearing any obstructions. With the soleplate removed, you will be able to check the internal hose and clear any threads or hair trapped around the brush bar.
If you would like a step by step guide, visit the Support section on our website at www.dyson.com.
I hope that you find this information useful.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 22, 2010
VacuumRepair
  • 438 Answers
SOURCE: I have a Dyson DC14
This sounds like your roller brush has stopped spinning for some reason. Turn the machine upside down when set to carpeting, and make sure the handle of the vacuum is down, as if you were in the vacuum posistion, and not up like the handle is when you're storing it.
Is your brush roller spinning? If it's not, there are two kinds of agitator brushes on the Dyson DC14, each has it's own troubleshooting.
If your beater brush is perfectly rounded in shape, then you have the newer style Dyson DC14 that doesn't use a clutch mechanism. Either belt has broken, or falled off, and is causing the brush not spin. Here's instructions with a pictorial on how to fix this problem;
Step 1. Unplug the vacuum cleaner.
  • Lay the machine flat on the floor and turn it over so that the base can be viewed.
  • Use a coin to turn the three soleplate fasteners and remove the soleplate as shown.
  • Check the brushbar for blockages and ensure the brushbar is rotating freely by hand.
  • If a blockage is present, carefully use a pair of scissors to cut away any hair and fibres from the brushbar ensuring you do not cut any of the bristles on the brushbar.
If the roller brush still doesn't spin after checking and removing any obstructions, then you need to replace the belt (or clutch if you have the early models). Here's a video that explains how to replace the clutch mechanism on Dyson vacuums;
If this failed to fix your problem, or if you have any other problems or questions, please feel free to just reply using the comment box below, I'm always happy to answer anyones questions or concerns. I hope this helped you. Please do be sure to rate my repair, or leave feedback for me if this helped. This is greatly appreciated by the Fixya community.
Chris Jones
GoVacuum.com
Posted on Jan 06, 2011
I can't switch from flat floor mode to carpet mode. I get no suction to speak of. Also, I get this horrible squealing noise when I push the red button
Your machine probably needs serviced and cleaned. What that means is taking it apart to clean hair, dust, and. debris from all the areas it builds up during normal use. If to much debris builds up it will start to cause to cause problems that can damage your vacuum. Start by trying to figure out where the horrible squealing noise is coming from as it probably means something is binding up, most likely in the brush bar area.
Dec 07, 2014 | Dyson Animal Vacuum Cleaner, Bagless, 24 3...
The suction on my dyson is too strong
i don*t know alot about dyson but if it has a thing to raise it up off the floor then that will work
Jan 26, 2013 | Dyson Vacuum Dc 14 Low Reach
My Dyson - DC14 won't push on my new plush carpet, front end
Same issue: new plush carpet, 7 year old tried and true DC14, wouldn't push across regardless of beater brush on or off. Called Dyson this morning, they suggested removing the small gasket between the floor plate and the assembly holding the beater brush. It's about a 12' gasket just under the screws used to remove the floor plate. Pushing is still a bit stiff, but it is a definite improvement. Whew!
Jul 29, 2012 | Vacuums
My DC24 will not switch from floor to carpet mode? Roller is not stuck or full of lint. Bagless is clean.
I'm sorry to hear you're having difficulties with your DC24. If the brushbar will not rotate when the brushbar switch is pressed, you may need to reset the machine.
With the cleaner facing you, you'll find a button in the red recess on the left-hand side of the cleaner head. Press this in until you hear an audible 'click' - it may help to use something like the eraser-end of a pencil to do this.
The brushbar will never rotate when you have the machine standing in the upright position, so please make sure you have it reclined into the vacuuming position before testing it after pressing the reset button.
This should resolve the issue - however, if you do need any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Dyson Online Customer Support
Jan 26, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
The bare floor/carpet switch moves on it's own from bare floor to carpet all the time.
I'm sorry to hear you're having difficulties with your DC07. When you have your brush control set to 'Carpets', the brushbar should run when the cleaner is reclined into the vacuuming position, and shut off when you stand the cleaner upright. When you have the brush control set to 'Hard floors', it should remain in the off position until you change it manually back to 'Carpets'.
If it won't stay in the 'Hard floors' position during use, it's probably best if you get in touch with us directly so we can determine if there's a fault, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Oct 22, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Just got my dc33... one issue... the dial switch to control btn bare floor / carpet mode doesn't seem holding in it's position when I set to the bare floor mode... it keeps coming back to carpet...
I'm sorry to hear you're having difficulties with your DC33. If you're concerned that the brush control doesn't seem to be staying in position, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to check everything is correct with your machine, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Aug 24, 2011 | Dyson DC33 Bagged Upright Vacuum
I have a Dyson DC-17 animal vacuum and the switch for floors will not come on. I am able to vacuum the carpets but am unable to turn off the roller to do floors. Also the hose with the floor attachment...
Sorry to hear you're having difficulties with your DC17 Animal. If you're experiencing issues with the brushbar on/off switch, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact with you as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Aug 15, 2011 | Dyson Vacuums
Dyson won't roll over carpet smoothly
Sorry to hear you're having difficulties using your DC14 on this particular carpet. It might help to check you have your brush control adjusted to the correct setting - you can find out how to do this in the user guide supplied with your cleaner. In case you don't have this to hand, here's an online copy:
http://media.dyson.com/downloads/us/floorcare/manuals/dc14_opmanual_usa2007.pdf
It's also a good idea to follow the steps shown in our online support guide, to check that the soleplate is correctly fitted, and that there are no blockages in the cleaner head:
http://www.dyson.com/support/help.asp?article=626&product=DC14-ANIMAL_US
You may wish to contact your carpet manufacturer to check it's suitable for cleaning with a vacuum cleaner equipped with a revolving brush. Manufacturers sometimes recommend cleaning certain types of carpeting using suction only.
If you have any further queries about using or maintaining your Dyson vacuum cleaner, please get in touch with us directly. One of our experts will be happy to provide the information and assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Aug 13, 2011 | Dyson DC14 Telescope Reach All Floors...
Brush will not spin
Hello :
Try this: switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
PLEASE RATE !
Apr 19, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
71 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
