Question about Epson Office Equipment & Supplies
Epson 322 keeps asking for pairing code cant find it on the printer
Everything in the instructions finds connection to router just won't connect to laptop keeps asking for code to pair but cant find one
    Sergeant:
  • 304 Answers
Try 0000 or 1234
Posted on Feb 18, 2015
Basti
  • 1447 Answers
SOURCE: bluetooth dongle
Not really, what operating system are you using? on the printer itself set it to bluetooth settings and dont put n a code set but set it to discoverable, then when printing dont do a file print, instead right click on the file and then on your send to option if your computer is detecting the dongle one option will say stylus rx585- then it will print it. one thing that you can check is as belkin manufacturer if their bt dongle is compatible with epson, and FYI bluetooth printng is for photo printng only. doesnt look as good if you are going to print a document or text docs..
hope this helps, and if you have inquiries email me back
if it solved your issue pls rate as fixya, thanks!!!
Posted on May 03, 2008
SOURCE: epson dx9400f wireless connect to dell laptop with vista
I HAVE A ESPON CX6600 PRINTER AND A DELL LAPTOP HOW DO I CONNECT THEM BOTH TOGETHER SO WHEN I PRESS PRINT IT WILL PRINT FROM MY LAPTOP TO MY PRINTER
Posted on Jul 21, 2008
SOURCE: HP Deskjet 460 mobile printer
Pin code is 0000
Posted on Aug 29, 2008
  • 8 Answers
SOURCE: Epson px700w wireless
If you have wpa2 then it will not connect. I had the same problem. When i changed my router settings to wpa (you can chosse wep as well) the setup continued succesfully. You can also set the printer from its own menu without a pc.
Posted on Mar 21, 2009
SOURCE: installed a lexmark pro200 printer to windows 7,
No need to contact technical support for this. I just figured this out. Press the button with the wrench icon underneath the power button. This will take you to a setup menu for wireless access. Push the button "ok" for push button access and a Pairing Code with appear on the LED screen. Enter this code into the field of your add printer/device setup field in Windows7. Press ok and the Lexmark will be setup. I never saw this as an answer on any webpage.
Posted on Jan 23, 2011
Can the epson R220 print wireless
It can't print wirelessly with the native hardware. It has a USB 1.1 connection. You may be able to find a print server that can connect to a wireless router. However, you will need to check the specifications. Some print servers will only work with select printers or OS combinations.
The specifications for the R220 are here: http://www.epson.com/cgi-bin/Store/consumer/consDetail.jsp?BV_UseBVCookie=yes&infoType=Specs&oid=58654761&category=Products .
I hope this helps.
(note since this is an older printer with a USB 1.1 connection, you can expect the printer to be slow with a wireless connection. If your signal strength drops, you may need to reboot everything (computer, print server, router and printer).)
Mar 21, 2011 | Epson Stylus Photo R220 InkJet Printer
I cant go wireles,keeps askin for security code.dont know it
I beleive its asking for your WEP Security Code. You must know it else you can ask your ISP(Internet Service Provider). If that dosent work out try this:
Go to control panel network connections and on wireless connection search for wireless connection available. If you find you wireless connection over there the connect to it. See if it ask for a password or not.
Oct 08, 2010 | NetGear DG834G Router
I have a Netgear WNR 2000 router for my home network. I am trying to connect an Epson NX420 printer. Instruction state to enter MAC address to router. I have the MAC address, but do not know how to enter...
I am not too familiar with NetGear routers, but all linksys routers have mac address filters, this allows the router to only accept connections from previously stated mac addresses. I never had to do such a thing for my wireless printer, but this could be the problem. Usually wireless printers just ask for a security code (WEP/etc.) and connect on their own. Sorry i cant be anymore direct.
Oct 02, 2010 | NetGear WGR614 Wireless Router
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
Hi I cant configure my router D-link DIR-300
Hi! I will be more than glad to assist u in this concern..Please dont use the setup cd or setup wizard. you can access the setup page of the router by typing at the url:192.168.0.1 then it will ask for the user name and password, by default the username is admin and the password, leave it blank.. here are the things u need to check before u setup u router.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 29, 2009 | D-Link DIR-300 Wireless Router
Fault 094-322
i have problem code 094-322 how cant i solve ?
May 22, 2009 | Xerox DocuColor 12 Color Copier
I just bought a solidtek ask-3462 bluetooth mini keyboard. Followed all the instructions but cant seem to connect. Please advise I cannot get the Solidtek Bluetook Super Mini keyboard to connect with...
I just went through this 30 minutes ago.
When you are asked for the passkey, click on generate passkey or choose one for me.
a passkey will appear on the computer
enter this passkey on the keyboard then press enter.
they should connect and pair properly.
Apr 12, 2009 | Solidtek Bluetooth Super Mini Keyboard
Epson Stylus CX6000 wont connect with my HP computer
download software from http://www.nodevice.com/driver/Stylus_CX6000/get46979.html
scroll down type verification code save down load to a folder (driversandsoftware) so you will always have it When complete install follow instructions
Apr 10, 2009 | Epson Stylus CX6000 All-In-One InkJet...
171 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
