Question about Logitech Computers & Internet
Letters and numbers will not type on my K260 wireless keyboard, mouse works as do the control and other keys what can I do?
Put new batteries in keyboard and removed and replaced receiver in USB. Seems to be only letters, fkeys, and numbers keys which are not responding on my K260 wireless keyboard mouse working fine.
SOURCE: keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Posted on Jun 26, 2008
IrishDruid
  • 2712 Answers
SOURCE: Logitech Wireless Keyboard not resetting evidently after installing new batts.
First make sure the batteries are put in with correct polarity. Although obvious, its surprising how many people make this mistake. (Happened to me too once :)
I am not sure what model you have, so please try the following:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=7652
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3818
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Nov 08, 2008
SOURCE: Logitech keyboard not working
try doing a system restore to when it was working
Posted on Dec 25, 2008
yooperbud
  • 8637 Answers
SOURCE: Wireless mouse not picking up
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 20, 2009
drifterK
  • 4924 Answers
SOURCE: My keyboard is n't typing? I have a laptop.
reinstall the driver ..and check the plugs for proper insert ...if there was a problem and you started the pc ..and do not sow the device ...( problem like unpluging ..or out of batteries..) it is the chance that you need to go to the device manager ..and update the driver ...( from the disc ) or automatically cause the driver is still installed into the pc ...
Posted on May 29, 2009
Keyboard won't work
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
Jan 15, 2013 | Lenovo b560 Notebook
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
Sometimes my wireless keyboard will type multiples of the same character when I've only hit the key once, and then other times it won't respond and will end up typing the first & last letters of a word...
Try plug it in to another USB port while the PC's switched on. It will force the computer to redect your mouse and keyboard and might fix the problem.
Another test would be on another PC or laptop. If it does the same thing then the keys are probably getting stuck down. Has it had anything spilt on it? Try a vacuum over the keys, you'll be suprised what gets caught under the keys (usally paperclips!!).
Dec 14, 2009 | Computers & Internet
My Microsoft Wireless receiver 3.1 quit working
Maybe the batteries need to be replaced, if that is not the problem try moving the transmitting device to a new spot and press the connect button. It is possible that the wireless system is defective and needs to be replaced. Depending on your version I believe that some had 1 yr, 3 yr and 5yr warranties. Check with Microsoft.
Nov 07, 2009 | Microsoft Wireless Optical Mouse USB...
Letters are typing as numbers
one of the F keys turns certain keys on the right side to number keys, so it can act like a full size keyboard with the 10 key panel on the right.. Look carefully at the F keys to determine which one it is. Or consult the manual.
Aug 31, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
When I type on the keyboard, sometime the letters will start typing as numbers. I accidently got my fingers on the F keys and I don't know if that is what caused this problem.
to check if you really press the Fkeys accidentally you can test all the Fkeys in your keybpoard then observe what are the effects of every FKeys you press. In that way you can surely check if the cause of your problem no in your keyboard is by pressing the Fkeys accidentally or if your keyboard has the problem.
Thanks
Jul 31, 2009 | Computers & Internet
ACER 5620 Extensa keyboard problem.
Hi, your Laptop has a integrated keypad. You or someone else might of turned this on, thankfully it is easily fixed. Just follow these steps,
1. Find and press the "Fn" key.
2. Find the F11 key there should be in blue letters "NumLk"
3. Press F11 while holding down the Fn key.
This should turn off the integrated keypad
Hope this works ~Kaleb~
Nov 12, 2008 | Computers & Internet
Keyboard not responding
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard wont work after battery change
remove the batteries for 2 minutes. Try pressing the shift or ctrl button when typing. Could be they are soft-stuck.
Sep 22, 2007 | Microsoft Wireless Laser Desktop 4000...
Computers & Internet Logo
50 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
