Question about Emerson GPS
New Emerson evc355wg camera will not hold charge. Will only work when connected to computer.
Charged unit. Inserted sd card. Connected to computer.
montecarlo
  • 50 Answers
SOURCE: Unit will not boot past Magellan splash screen
try to press the reset button on the left side next to the usb port with a small paper clip or toothpick and see what happens and see if it did is firmware update,if not do it over and the unit plugged in with powersupply and the usb and leave it alone and let it reset a few times until it says to unplug from the usb .for the sd card make sure is a flash sd card.i have a mastreo 4000 with a 2gb sd flashcard and it has no problem.theses units has unlimited amount of any size of gb sd flash card.let me know what happens.
Posted on Mar 02, 2008
  • 638 Answers
SOURCE: SD card access problem (nuvi 660)
Try seeing if your computer can recognize the card in a card reader. Your SD card might be corrupt.
Posted on Sep 30, 2008
  • 20 Answers
SOURCE: SD card can not be accessed on Sanyo NVM-4370
Did you hear a beep when SD card is inserted? Did you also try to hard reset the unit using the On/Off switch located at the bottom of the unit? Try with another SD card and see if the SD option is selectabe. If all have tried I suggest you to exchange for another unit. HTH.
Posted on Mar 05, 2009
  • 171 Answers
SOURCE: TomTom One series 30 won't reset
It sounds like you have lost the operating system or the flash memory card has gone bad. Make sure your unit is fully charged and try again. Then connect your device to your computer. If it comes up in my computer right click the drive and check properties to see how much space is availiable on the drive. If it says 0 the flash has gone bad, I have a 20 series tt that this happened to. My solution was to insert a sd card (at least 2 gb.) into the sd card slot found under the sticker no sd card requaired on the bottom of the tt. TT home then installed the operating system but the downside is if you have not made a backup od your tt you will have to buy new maps (not cheap).
Hope this helps
Posted on May 04, 2009
  • 1111 Answers
SOURCE: Cannot go past usb is connected, or battery charged notice ?
disconnect it from power, then turn it on and after its done booting, use a paper clip and insert it in the tiny hole on the left side (thats the rest) and depress the switch gently...it should now start to reboot, after its done, plug in the charger again....if you still have a problem, let me know by replying to this post.
bill
Posted on Feb 28, 2010
We have a brand new emerson actioncam model EVC355WG that does not turn on
Sadly it seems those models have battery issues, make sure you leave it charging overnight the first time. Otherwise take it back.
Don
Dec 30, 2014 | Emerson Televison & Video
Camera will not hold charge
Built in battery is dead and will need to be replaced. Depending on what camera you have you might be able to do it yourself.
Dec 07, 2014 | Cameras
I can't figure out how to get music onto sd card for Bluedio R headset
  • The MicroSD Card format needs to be FAT32.
    32GB max for the H+ and 64gb max for the R
  • It works better to use your own card reader to do file transfers.
  • Documentation says that with the unit powered on, you hold down the wheel button to enter SD Card mode. (Light goes green)
  • Windows will install some generic SCSI drivers and a new removable drive should show up in Computer
    Then you can copy files over the USB connection.
Dec 31, 2013 | Bluedio Model R - Wireless & Bluetooth...
Built in memory full and I have only taken one photo.
Have you inserted an SD card as the built in memory on the camera is only 12.7 Mb big so an SD card should be inserted. Hope this helps.
Jul 04, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
Hi, I tried to install this Transcend micro sdhc 8 GB memory card. I would have read the installation instructions, but my bionic eyes couldn't read the stupid instructions. So I inserted it properly...
You can only format a microSD card when it is unmounted. Unmounting a microSD card-To unmount a microSD card, follow the instructions below: [Menu] >Settings&tools>Press Ok key >SD card & phone storage(card memory)>Unmount SD card Formatting a microSD card>[Menu]>Settings&Tools>SD card & phone storage(card memory)>Format SD card.
Aug 23, 2011 | Cell Phones
The unit was connected to a main 220v in the house and not in car, also the battery was 3/4 charged.If some fuse it was, it had to be in the unit itself. when this happened I was exploring finding...
Is that SD card have maps on it?
Did you check to see if the SD card is listed in the maps and chosen or looking for the old map?
With the SD card out turn on the unit
GO to your map... in my nuvi i have to go in this way
Tools..... Settings.....Maps.... on screen press Map Info
Is there a check mark there in City Navigator No American NT
That is the map your unit is looking at....... if you add your SD card now and want to use that map put card in unit it should pop up
Make sure that only the SD card will have a check mark to use that map
hope this helps
Oct 27, 2010 | Garmin 255WT GPS Receiver
Digital picture frame does not work after being charged overnight
I returned the product and exchanged it for one that worked in the store.
Nov 28, 2009 | Cameras
Hope this helps
Apr 23, 2009 | Tomtom One XL GPS Receiver
Mar 02, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
GPS Logo
387 people viewed this question
Top Emerson GPS Experts
Are you an Emerson GPS Expert? Answer questions, earn points and help others
