Question about Cameras
Camera will not hold charge
Connected to computer. Inserted sd card. Fully charged unit.
  • 1,915 Answers
Built in battery is dead and will need to be replaced. Depending on what camera you have you might be able to do it yourself.
Posted on Dec 10, 2014
SOURCE: Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
Posted on Feb 21, 2008
SOURCE: FUJI F20 Won't Power Up - Good and Charged Battery
Fuji FinePitteryx refuses to power up,even after new lith. batteries were installed
Posted on Oct 09, 2008
Steve5
  • 423 Answers
SOURCE: Card error with compatible memory card (Z30fd - Fujifilm)
Try doing a "format" of the card through the set-up menu.
Posted on Aug 08, 2009
Ranglo
  • 1194 Answers
SOURCE: canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
  • Direction of your battery might be wrong, Check out and put it again.
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Check whether Memory Card/Battery Cover is properly closed.
  • Load new or fully charged battery.
  • Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Posted on Mar 05, 2010
  • 1705 Answers
SOURCE: Just bought FUJIFILM FinePix JV100 charged the
Take it back to the vendor, tell them your problem and ask them to demonstrate the camera to your satifaction. If they can't request refund or replacement.
You should have any problems with a new camera.
Posted on May 01, 2010
Will NOT turn on when sd media card is inserted
look through the SD slot, all pins should in position and clean, if something looks wrong, try to clean or adjust the pin with philips #000 screw drive or similar size tools
if everything looks just fine, try to put another SD card.
if nothing works to you, through it to trash or sell on ebay.
Jan 28, 2014 | Kodak EasyShare M380 Digital Camera
My camera has not been able to turn on since i bought it
It could be that the battery has not fully charged. Do you have a stand-alone charger or are you using the USB port of your computer to charge it? A stand-alone is usually quicker but allow 2-3 hours if charging from the USB/Computer. Then disconnect and plug back into the computer. If it is not "recognized" by the Operating System (i.e., places a new drive letter on the "My Computer" screen), it is probably defective. Return to vendor if still under warranty. Another thought: Make sure you have a formatted SD card inserted into it. Most of these type spy cameras will not turn on (or only stay on 30-45 seconds) if no media card is present.
Jan 31, 2011 | FPS Lighter Camera Spy Mini Dvr Camcorder...
FUJIFILM A170 Digital Camera will not take photo
check to be certain the battery is holding a charge, is inserted correctly, make sure the SD card is inserted correctly, IF it is holding charge and card is in correctly is the card full? if so empty it. if you have a SD card slot in the computer see if there are photos on the card if you dont have one in your computer and the camera hooks to the computer DONT DO IT! take the card to walmart, walgreens or somewhere they can see if something is on the card. we are trying to see if its a battery problem a card problem or a Camera problem. if the card is good and has no photos then put it in the camera and asuming the menus come up then format the card. try taking photos if this works great if not see if a friend will barrow their card to you to try in your camera make sure again that their card is BLANK otherwise if you have a bad camera it can blank their card too and you are SOL. try online and search for the model and see if you come up with others that have the same problem. read the manual and if you dont have it do a manual search for the camera model.
Jul 22, 2010 | FUJIFILM A170 Digital Camera
BATTERY DOES NOT CHARGE Received a "Vivitar T328" camera yesterday. Inserted the supplied battery and a new memory card into the camera and connected the camera via "USB" cable to the supplied charger....
How old is the battery? If the battery is refurbished or old it might just not charge anymore.
Also, do you have a separate charger for the battery? Many cameras do and that is how they charge, not when the battery is still in the camera.
Apr 09, 2010 | Vivitar ViviCam T328 Digital Camera
Jun 07, 2009 | Fuji Finepix Z20fd Digital Camera
TomTom One series 30 won't reset
It sounds like you have lost the operating system or the flash memory card has gone bad. Make sure your unit is fully charged and try again. Then connect your device to your computer. If it comes up in my computer right click the drive and check properties to see how much space is availiable on the drive. If it says 0 the flash has gone bad, I have a 20 series tt that this happened to. My solution was to insert a sd card (at least 2 gb.) into the sd card slot found under the sticker no sd card requaired on the bottom of the tt. TT home then installed the operating system but the downside is if you have not made a backup od your tt you will have to buy new maps (not cheap).
Hope this helps
Apr 23, 2009 | Tomtom One XL GPS Receiver
Camera
Please check the following things when the camera does not turn on.
Possible causes and how to handle them
1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
If your camera does not operate after checking each of these things, or if there is any visible damage on your camera that could be the cause, please contact the nearest Service Center.
Courtesy: http://photography-on-the.net/forum/showthread.php?t=151603
Jul 20, 2008 | Olympus FE-210 Digital Camera
Kodak easyshare z730
May 19, 2008 | Cameras
1G SD card "Cruical"
Make sure your SD card is really snugly inserted to the device. Also check your SD card compatibility list on the manual. Some SD cards have issues with electronic devices.
If the card is read on your computer, try reformatting it..
Dec 14, 2007 | Jazz DV-179 Digital Camera
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
