The washing machine won't drain or spin. What can I do?
Looked in manual
    New Friend:
    Problem Solver:
  • 12 Answers
There are two gears on the top and bottom of the wash machine motor. This makes the machine spin and agitate during the wash cycle. They are made of plastic in most cases. One of the gears broke and needs to be replaced. The parts are inexpensive. You can order them from one of the discount parts providers online. If you are mechanically inclined, you can install them yourself. replacementparts.com, ereolacementparts.com or sunberg.com
Posted on Dec 08, 2014
heatman101
  • 43501 Answers
SOURCE: Maytag Neptune washing machine - wont drain & spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 22, 2010
SOURCE: We have a Fisher &
Try draining it manually, if that does not work you may have a blockage, theres a good video fix on you tube
Posted on May 19, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: PYE Washing Machine AWM800 won't
Hello
This is a drain pump error code.The pump is either jammed or clogged.It will need to be removed and cleaned out.
Posted on Jun 19, 2011
  • 2006 Answers
SOURCE: My LG WT-R807 8KG top
Did you try it in other cycles (delicate, permanent press, etc.)? The more symptoms - what works and doesn't allows better advice. Because right now it could be the control board, the timer, the drain pump and more.
Also you need to give us the model number off the id tag in your unit since that once keeps coming back as invalid.
Posted on Jul 14, 2011
SOURCE: Kenmore 300 Series Top Loading
wont work at all in spin cycle the started switch stops working in spin cycle
Posted on Aug 01, 2011
After washing it makes loud noise & won't spin or drain
You shoul inspekt water outlet on the bottom of the drum. There is mabye something inthere.
Dec 02, 2017 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
How do you replace the lid switch on a Kenmore 70 series washing machine
Hi.
Check for drain blockage at the filter. Check setting of drain hose at the back. If there is no drain problem check pressure switch, central control unit and pump motor.
Here a tip talking about drain and spin problems: http://www.fixya.com/support/r7775926-no_spin_tip_all_washers
Nov 13, 2011 | Kenmore Washing Machines
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
Washing machine won't rinse and the water won't drain out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2011 | Washing Machines
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
Top Washing Machines Experts
