Question about LG Washing Machines
How can we solve this problem lg model (wf-t1122tp)
When turning on machine all we are getting is PE
  • 6 Answers
You'll have to provide much more detail if you want an answer on this. How about a photo of the condition to start with? Do you have any manuals of the machine?
Posted on Dec 14, 2014
  • 210 Answers
SOURCE: PE error code on LG WF-T653A
PE is a pressure switch problem. Could be a bad switch or it could be that the hose is plugged. The switch looks like a diapharm switch and is located on the main board. It has a black hose that connects under the bottom of the tub. See if that end is clogged. Otherwise you may need a new switch.
Sgt 48
Posted on Jun 02, 2008
drsn
  • 42 Answers
SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
drsn777@hotmail.com for more info.
Posted on Dec 15, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
http://www.jordansmanuals.com/ServiceManuals/LG/Washing/WF-T753A/WF-T753A%20Service%20Manual.pdf
Posted on Dec 27, 2012
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
LG model (WF-T1122TP) we are trying to wash all we getting PE what that means
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Dec 07, 2014 | LG Washing Machines
LG wf-t652a displays an error "PE" & dinging when turned on. Any suggestions.
Pressure sensor error. Check also the pressure hose. The pressure sensor stops the water at a set level depending on the cycle you choose.
Jul 16, 2014 | Washing Machines
Error message - PE.... on lg intello washer. my washer is full of clothes and water.it won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
Nov 21, 2017 | Washing Machines
What is the problem if the LG Fuzzy WF-T1330TP top loader shows error code PE.
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
Apr 08, 2011 | LG Washing Machines
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
63 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
