Question about Electrical Supplies
We are wiring a new ceiling fitting our old rose has two black wires two red wires and two earth wires new fitting has just three wires how do ee wire this up to stop it blowing system
Two reds to live two blacks to neuteral and two earths to two earths. This blew fuse. One red to live two blacks to neuteral and earths to earths light stayed on continuously no switch working, swapped the red and no light at all
    Problem Solver:
  • 7 Answers
Gene's right, in that you should test for electrical function of the wires you've got. It's not obvious how to do that, so you probably will need to study up on it, via his link or elsewhere. Or just hire an electrician -- the safest option. You can't assume that color coding of wires means anything in particular, because non-electricians may have messed with it in the past, and if it's an old house its wiring may predate color coding. That said, red is often used for switch wiring. From your description I'd guess you've got at least one switched circuit for a light fixture, and, if a ceiling fan once lived there, a separate switched or non-switched circuit to run the fan motor. But you don't give enough info for me to be more specific. I'd expect to be seeing white wires too, in which case white would (probably) be neutral, black hot, and red switched hot (i.e. hot if the associated switch is on). Sounds flaky -- call an electrician.
Posted on Dec 27, 2014
  • 5,245 Answers
3 Suggested Answers
SOURCE: I am hooking up a
1) Look at screw color.
New device has brass screws on one side, and 1 silver screw for each switch located on other side of device.
Hot wire goes to brass screw.
Wire to fan goes to one silver screw
Wire to light goes to another silver screw.
Wire to heater goes to another silver screw.
If you do not have a wire for each individual Load, then you will have to add wiring.
2) Electricians don't guess, they test.
Separate wires for testing.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire.
Hot wire connects to brass-colored screw.
If any wires on old switch was connected to same Hot wire, then also connect that wire to brass-colored screws.
Hot wire is identified.
Test Hot wire to each other wire in box, except bare ground.
Tester lights up on Neutral wire. Neutral wire will NOT connect to this switching device.
Next, connect one of the remaining wires to a silver screw.
Turn power ON.
Flip switch to see what Load that wire controls.
By process of elimination, add wires to each silver screw and test each by flipping switch.
Breaker will trip if you connect Neutral to silver screw.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Posted on Jan 10, 2011
SOURCE: ceiling rose nt working
Look for the manufacturer's wiring on line or if the product is still available ask a merchant to permit you to copy the schematic from a similar product as yours. If they want future or continued service to you they will most likely accommodate you.
If that does not work, have a certified electrician look at it to sort out the three black and four earth wires.
Posted on Nov 15, 2011
Sounds like another wire connection for having two each. Here's what US AC electrical wiring:
Usually black or red = HOT
White = Neutral (current carrying)
Green = Ground
Dec 07, 2014 | Dryers
Twist the current pairs together and then twist the white (neutral) to your red pair, the black (hot) to black, and green (ground) to green.
How do I fit outdoor light
Electrician. That way you wont get shocked. You cannot see electricity
Aug 28, 2014 | Electrical Supplies
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
Brought LED back light the wires black,red,yellow, the old back light on my bike as two bulbs with six wires 2 x red 2 x blue 2 x black n yellow.three too each bulb when i connect my new light too bike...
Hi, firstly dont think for a miniute that the black wire on your new light is the earth, using the battery as a power source put one of the wires to earth and the other to live, as the led light will only work if the power is conected to the rite pole it is important to establish wich of the new wires is earth, you may have to swap them around to get the correct order, and then conect each of the other wires to the batt poss to check the lite works,when you are happy you have the correct order you can fit it to the bike, on the kawasaki blk and yellow is earth , although you have 6wires they are only 3wires in the loom wich double up to 6 for the 2 bulbs in the lite unit, you can leave 1 of eah colour disconected,
Mar 12, 2011 | kawasaki VN 750 Vulcan Motorcycles
Ceiling rose nt working
Nov 13, 2009 | Cooper Industries Cooper Wiring 2158V 3...
I have a plug outlet that's powered by a three
Red wire is the live wire, black wire is the dead wire, white wire is the earth wire.
Now its the black and the red wire we are to play with. take a two wire cable, let the wires be red and black in the new cable, connect the red and the black cables of the new cable to the corresponding red and black wires of the old cable i.e. the new cable is to be connected parallel to the old cable(the connections can be made by ripping the old cable from any point) now connect a switch to the other end of the red wire. attach the terminal of the bulb to:
1) the the other terminal of the switch
2) the other end of the black wire
Sep 02, 2009 | Christmas Lights Etc Santa's Toy Truck
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
Electrical Supplies Logo
78 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
