Question about SATO CL408e Label Printer
After hitting the print button. the printer is asking for the output file name. what file name to input please?
NEED TO PRINT LOCATION LABELS, BUT INSTEAD PRINTER ASK FOR OUTPUT FILE NAME. I DONT KNOW WHAT OUTPUT FILE NAME TO INPUT.
    Habit-Forming:
  • 91 Answers
After chose print, clear (print to file) check box
Posted on Dec 08, 2014
checkitright
  • 1362 Answers
SOURCE: Setup problem
You can find the free manual here:
http://www.satoamerica.com/Operator+and+Technical+Manuals/98
Good luck
Posted on Oct 30, 2007
SOURCE: printer problem
check baud rate on NIC card (pull out NIC), against COM settings on PC. they must match. 9600 usually works
Posted on Jan 14, 2008
SOURCE: Pls help in this VB code, Sato CX400 barcode printer
jst try this u create a label from label printing software using ato font then make a prn
then attach u r vb code in to prn it will work
rohitjain
prn example-------------
A
Z
A
CB+18
Z
A
CD250,3300
Z
A
AR
Z
A
A100950647
Z
A
%2h416v0072BG01031>H23456111
%2PSP02h573v0021L0101XS922
%2PSP02h618v0021L0101XS18K
%2PSP02h415v0089L0101XS17125
%2PSP02h416v0039L0101XSPO124
%2PSP02h416v0022L0101XS215gms
%2PSP02h618v0043L0101XSDR37/0.20
%2PSP02h618v0064L0101XSDR37/0.20
%2PSP02h618v0085L0101XSDT/B44/0.82
Z
vb code example------------------
Open "LPT1" For Output As 1
Do While rs.EOF = False
For I = 1 To Val(Text1.Text)
Print #1, "A"
Print #1, "*&"
Print #1, "Z"
Print #1, "A"
Print #1, "CB+18"
Print #1, "Z"
Print #1, "A"
Print #1, "CD250,3300"
Print #1, "Z"
Print #1, "A"
Print #1, "AR"
Print #1, "Z"
Print #1, "A"
Print #1, "A100950647"
Print #1, "Z"
Print #1, "A"
X = "%2h380v0065BG01031>H"
Y = rs.Fields(6).Value
X = X + Y
Print #1, X
Print #1, "%2PSP02h618v0085L0101XSKT"
Print #1, "%2PSP02h600v0085L0101XS", rs.Fields(1).Value
Print #1, "%2PSP02h618v0064L0101XSNetWt"
Print #1, "%2PSP02h600v0063L0101XS", rs.Fields(2).Value
Print #1, "%2PSP02h618v0043L0101XSDiaWt"
Print #1, "%2PSP02h600v0041L0101XS", rs.Fields(3).Value
Print #1, "%2PSP02h618v0021L0101XSColWt"
Print #1, "%2PSP02h602v0021L0101XS", IIf(IsNull(rs.Fields(4).Value), " ", rs.Fields(4).Value)
Print #1, "%2PSP02h430v0084L0101XS", rs.Fields(5).Value
Print #1, "%2PSP02h371v0028L0101XS$"
Print #1, "%2PSP02h405v0028L0101XS", rs.Fields(7).Value
Print #1, "&"
Print #1, "Z"
Print #1, " A"
Print #1, " #E5"
Print #1, " Z"
Print #1, " A"
Print #1, " CS2"
Print #1, " Z"
Print #1, "A"
Print #1, " 0000"
Print #1, "TEXT1.TEXT"
Print #1, "/"
Print #1, "Z"
Posted on Feb 14, 2009
  • 54 Answers
SOURCE: sato printer output print end
check that print buffer is 1 item
Posted on Feb 25, 2009
SOURCE: Please help abt VB6 code for SATO CX400 printer
just make prn file or by crystal report
call me on 9974985001
Posted on Mar 26, 2009
Output file name
i installed a lexmark printer and when i try to print it ask for an output file name. and the print to file box is not checked..which would mess it up if it was checked.
Mar 04, 2010 | Lexmark T644 Laser Printer
My canon mx330 printer ask me this questions when i hit the "print button" it pops up a window that asks"output file name"? I'm suppose to type something inthere?
Check that the printer shown in the print window is the MX330. It sounds like your default printer is set to be a virtual printer such as Microsoft XPS or Acrobat PDF. You need to set the MX330 as your default printer by going to your Printers and Faxes window, right-click on the MX330 printer and select "set as default" on the list there.
Oct 23, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Cannot print a pdf
Are you using Adobe Writer, try un installing and reinstalling
or download a app like freepdf
let me know, cause the solution depends on what software you are using.
Aug 21, 2009 | HP Photosmart D7460 Printer
What is print to file? What is output file name?
It is windows way of storing a document for printing later.
It will save the job you want to print at another time but ask you for a file name so that you can give it a name you will remember.
It will do this if it is set as the DEFAULT printer.
To change that and provided you have a printer installed then go to CONTROL PANEL / printers and faxes / then right click on the printer you want as the default and on the box that opens will be that exact option, click it and you are done. it wont ask you those questions again.
If this information was useful please click below
Aug 19, 2009 | Konica Minolta magicolor 2550 EN Laser...
When i print it ask output file name
go to printer properties & check out this option. if problem does not resolved then reinstalled printer driver.
Aug 15, 2009 | Samsung SCX-4300 Monochrome Laser...
Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Mar 06, 2009 | Zebra LP 2844 Thermal Printer
Can't print a pdf file
Sounds like you are using the PDF printer as your selected printer - this is for creating PDF files in which case you would give it a name.
If you have a PDF file open, simply select your printer (1610) as the printer to print to as with any other documents you print.
Dec 29, 2008 | HP PSC 1610v All-in-One Printer
Does not print. Asks for output file instead.
The default printer is set to be "file". Here's what you must do:
- Go to printers dialogue box and right click on your printer name and selectd "Set s default printer"
 - Right click on printers name and chose Properties. then look for a check box saing something like "print to file" and unchek it.
This sould resolve the problem.
Best regards
Nov 12, 2008 | HP DeskJet F380 All-In-One Printer
Its keeps asking for my output file name when i go to print.what is a output file name ?
Sounds like whatever your printing to is set for print to file or your default printer has changed.
Go into the control panel, select printers, select the printer that you want to use and press the right mouse buttons for properties.
Select the ports tab and make sure that the file box isn't checked and that the USB port is (or whatever port your printing with).
Press ok
Make sure that you printer is set for default printer.
Jun 10, 2008 | Office Equipment & Supplies
Consistantly Intermittent Connection Problems
If you've tried installing the latest drivers and the problem persists it sounds like you have a lemon. The printers have a 2 yr warranty, so I would contact the retailer you purchased from and replace the printer. If your labels are jamming. Try the compatible File Labels available at LabelValue.com. They have both the Dymo 30327 and Dymo 30277 labels in a compatible version.
Feb 29, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
SATO CL408e Label Printer Logo
189 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
M_Butkus
Howard
Howard
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
