Question about Kenwood MX270 Patissier Food Processor
My Kenwood MX270 patissier doesn't work anymore. I've opened it and checked the brushes (still enough length) ; micro switch also is working. Which component on one of the two prints are suspicious?
My Kenwood MX270 patissier doesn't work anymore. I've opened it and checked the brushes (still enough length) ; micro switch also is working. Which component on one of the two prints are suspicious? Does anybody know?.
  • nader
    nader Apr 18, 2015
    I have the same issue and i did exactly as you did, and i am thinking about the two boards also, but which one don`t know, and the one with the coupling sensor can`t find it on internet, no one sell it ? do u have ideas sir?
  • Kenwood Master
  • 16,181 Answers
Brushes are long enough but it there enough pressure on them to press against the armature? What about the armature? Did you use a meter to check the windings?
Posted on Apr 18, 2015
No turning of motor in my Kenwood MX270 Patissier
Follow the power, start looking wherever the power stops. Sometimes it can help to reverse phase & neutral to track where the power stops from the other side too. You are only doing this for testing purposes and need to put it back as it should be when you're done.
Dec 08, 2014 | Kenwood MX270 Patissier Food Processor
Moter is working but dooh hook not working
hi if you still have problems email me and i will try and talk you through,
it may be the belt (teeth worn out) or the pulley (same problem).
the info given in your post is very vague.
if its the teeth on either the belt or pulley there is a simple fix.
remove bottom of base with screwdriver there should be screws under the feet of machine. use a bike valve screwdriver to remove the two remaining screws(depending on make and model)
remove belt, put RUBBER BAND
Jan 24, 2013 | Kenwood MX270 Patissier Food Processor
Kenwood KM336 no power to beater or slow speed outlet
Hi. You have a broken gear in the gearbox either the first motion gear is loose on its shaft or less likely the vertical big gear is loose on its shaft. independent spares for the gearbox are available or complete gearbox
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Dec 20, 2011 | KitchenAid Food Processors
I need a service manual for the MX270. Don't know how to open the machine.
How far have you come? There are covers in plastic that cover the screw heads.
Have you got any other information, I have an electrical problem. Need help with electric troubleshooting.
Jan 03, 2011 | Kenwood MX270 Patissier Food Processor
Kenwood a710a mixer suddenly lacks power
sounds like the motor armature is burn. Dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper colour. I the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor.
Feb 04, 2010 | Food Processors
Kenwood MX270 Patissier Food Processor Logo
173 people viewed this question
Top Kenwood Food Processors Experts
Ross Keen
Mitch Vass
Mitch Vass
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
