Question about Generac Electrical Supplies
How can I get a generac 20kv stand alone generator to run on the unrefined natural gas from my personal well
Just research
    New Friend:
  • 17 Answers
What is the BTU content of your natural gas? and how much does it vary?
Posted on Dec 13, 2014
Generac troubleshooting
please send me more info about this generator I need a model number is this a natural gas or propane I have a neighbor that just had one installed I might be able to get some info from him to help you
Aug 30, 2014 | Generac 17 Kw Air-Cooled Standby Generator...
One cylinder not firing on generator
If you have spark and compression and it not firing then you must not have fuel. the fuel is fed from the demand regulator thru the intake independent for each cylinder. Check the intake and make sure that the NG/LP pin is all the way to the NG side.
Jul 21, 2014 | Generac Guardian 20kW Model : 5875
Generator alarm underspeed
When you get the under speed alarm is the generator under load? Try manually starting the generator with no load and let it run for a while, if no alarm, then put it under your home load and measure current draw (maybe have an electrician check it) if the amp draw and in rush caused by compressors, pumps motors etc are within the generator rating, check your fuel pressure, on average 8-11 WC Nat gas. Pressure may test well under no load but drop starving the engine of fuel unde rload. Underspeed is just that engine cannot make RPM/Frequency
Nov 28, 2013 | Generac Power Systems Generac 5522 14 Kw...
I have a Generac 60kw generator. When it runs under load the generator surges, causing the lights to go up and down. The only way to stop this is if I reach into the generator and grab what I think is the...
You did not specify fuel. If running natural gas or propane, check the diameter of your feed line. You need at least 1/2 to 3/4 pipe diameter on the NG or propane. At 60KW I would guess at least 3/4 maybe larger for NG.
Sep 16, 2013 | Generac Power Systems Commercial Series...
My standby generator is just cranking but wont turn all the way
If it was installed only five months ago, it should still be under warranty. Call Home Depot and have them send out a repair person.
Jul 01, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Start runs shutsdown
Typically caused by the fuel line (LP or Natural Gas) having a lot of air in it. Was your generator just installed, or was there any work done to the gas line of the building / generator? Consult local gas contractor / propane dealer / gas company for assistance in purging the fuel line.
A low battery can also cause this as well as the generator is not able to come up to starting speed quick enough. Try placing a stand alone battery charger on the generator and charge the battery. Also check the air filter as well.
OverCrank condition occurs when generator tries to start itself, or be manually started, and the starter spends too much time turning.
This can also indicate failure of the control board. This will need the expertise of generac technician. Call 1-888-GENERAC (1-888-436-3722)
M-F 7am-6pm Central
Mar 29, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
101 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
