Question about Ice Cream Makers
I need to buy mixing blade for my ice cream maker HOMICE 1518 SKU 3256 thank you
I need to buy a new ice cream mixing blade
find your brand & model then look on-line e-bay etc...............or contact a dealer or parts distribuitor etc....
Dec 08, 2014 | Ice Cream Makers
Maverick ice cream shoppe
I have one and a working unit all except for the freezer bowl. That corroded.
Jun 07, 2012 | Maverick MIC-001 1 Quart Ice Cream Maker
Need lid and belt
Electra-Craft in New Jersey at 800 223-1898 was very helpful to me.
Their website lists belts, lids, mixing blades, lock nuts, and manuals.
http://store.electra-craft.com/catalog/search?keyword=simac
Oct 28, 2011 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
I have an ice cream maker ice 45u but the mixer blade is not turning. The power is there because i can hear it and when i pull the leaver down the cogs turn on the sprinkler system are turning i have...
Check that all gears are in good working order. The paddlewill not turn properly and the motor will not run if the gears are worn ordamaged gears. Inspect the paddle for damage and replace if necessary. You alsomay need to replace worn or damaged gears in the motor. Lubricate the motor,drive shaft and motor bearings. Hope this will help you. Good Luck.
Sep 03, 2011 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Taylor 8756 ice cream machine clogs at face
i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
Richmond Ice Cream Maker blade for Model 78 4 quart
I am need of a new can for my Richmond ice cream freezer model number 78 that a 4 qt. please help me to find this. It is electric.
Mar 09, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Where do I find the mixes to use with Rivalgc8101
The most widely available ice cream mixes come in packets and are made by Rival, Hamilton Beach and Junket. Rival is the most widely available in department stores like Wal-Mart, Target and Shopko, but they may only carry the packets in the summer. They will usually be in a cardboard display box near the ice cream makers themselves. You can also buy them from various retailers on Amazon.com or, in the case of Junket, directly from the manufacturer. See http://www.junketdesserts.com/icecreammix.aspx for Junket's on-line offerings.
That said, none of these powdered mixes come in any other flavors than vanilla, chocolate and strawberry. For caramel-rippled ice cream, make the vanilla as usual. When the ice cream machine is done, scoop it into another container, alternating some caramel topping as well. Pack lighly, cover and freeze hard. For the banana, you could try adding a couple of completely mashed bananas to any of the flavors.
Jan 26, 2009 | Rival GC8101 1 Quart Ice Cream Maker
Mixing Arm Doesn't Turn
As long as it makes the ice cream, it doesn't matter which one turns. If it's not making the ice cream, call Cuisinart, as both the lid and the mixing arm can be replaced.
-Tha Mp3 Doctor
Jun 04, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Ice Cream Makers Logo
81 people viewed this question
Top Ice Cream Makers Experts
ray gallant
Ruth summersides
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
