Using standard on tv remote and normal on cable remote both settings crop the edge of the picture
  • 71 Answers
TVs that use cathode ray tube (CRT) cannot display the correct aspect ratio for movies and modern TV broadcasts unless it is in letterbox form. Unfortunately most of the older CRT TVs do not have a letterbox setting.
Posted on Dec 08, 2014
The edges of my tv picture are left off the screen. for example the by lines on a news programe are halve missing. even when using normal aspect ratio
Which settings are you using! The ones for the cable box or the ones on your TV itself. They both have aspect features!
Dec 07, 2014 | Televison & Video
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
No picture
tried to reset the tv.
Sep 18, 2012 | Televison & Video
My philips tv has an expanded picture,meaning the picture is so large does not fit the tvscreen. and my remote control is broken can i buy one?
You can purchase a remote or get yours fixed at www.replacementremotes.com
BUT the picture size is normally adjusted with your cable/satellite remote or from within the cable box's/satellite receiver's menu. On the cable box remote the button is usually #hdzoom and on the satellite receiver it is usually aspect or format. For settings make sure the set top box is set to 16:9 disabling any 4:3 override. Set to 1080i fixed or 720p for the resolution. You may have a choice of 1080i cropped, stretch, wide or etc. and that is where you play around with the settings in order to get the right size picture.
May 11, 2011 | Philips Televison & Video
Its like the picture is zoomed in cutting edges off, like sports games it cuts scores off top, i can only get to seich between standard format and wide expanded its been fine uuntil now i dont kow if maybe...
Pls be sure the tv is in 16x9 format(the original tv remote) then check the cable or sat remote to be in the "normal" Cable remotes often press cable then the pound or zoom key..........Sat remotes press sat then the format key
Feb 06, 2010 | Mitsubishi WS-73513 73" Rear Projection...
The whole picture does not show on the screen; faces on the edge are cut off
It's one or two problems. It depends on if you're using a cable box. First try to see if your aspect ratio is on full using the JVC remote. Just Press the Aspect button. Then if it's on full and this doesn't correct the problem it may be your cable box. If it's time Warner go into the settings by pressing the settings button on the remote twice I believe tehn go to display and select the select and check each option picture size (change to normal if you have a 4:3 t.v. or stretch if you have a 16:9 (wide screen T.V.) Then go to aspect ratio and select again eih 4:3 or 16:9. If your have a hdtv cable box select output resolution and make sure there is a bulllet next to each setting for 480i, 480p, 720p and 1080i. Then exit out of the cable settings and your picture should be ok. Now if you have the hdtv package keep in mind it is normal to have the black side bars on each side of the picture only if your watching one ofthe high definition channel network that is not actual being broadcast in hdtv or recorded in hdtv.
Oct 14, 2009 | JVC AV-32D305 32" TV
Xbox 360 hd and p56926
change back to 480 resolution and them go upscaling
Feb 20, 2008 | RCA P52926 52" Rear Projection Television
PICTURE CUT OFF
Push the "Ratio" button on your remote and see if that helps. I am assuming you are connected to either a cable or satellite box. If pushing ratio doesn't work, it may be a setting in the box. Post what kind of box your using and I will see if I can help.
Jan 22, 2008 | LG 42PC3D 42 in. Plasma Television
Picture partially cropped at bottom of screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Dec 24, 2007 | JVC AV-27230 27" TV
Picture edges blurry
There is a setting labeled cropping... turn it on.
Nov 19, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
